its been awhile, 73' 914 restore |
Brasil914 |
Mar 12 2020, 10:23 AM
Newbie Group: Members Posts: 26 Joined: 7-March 17 From: Charleston, SC Member No.: 20,905 Region Association: South East States |
hello again my fellow 914 enthusiasts it has been several years since I have visited or posted. any who I am trying to find a replacement distributor for my 2.0L it is D-jet equipped and I had found that the 039-905-205 A/B/AX have all been discontinued with no parts. I have com across an AU that is special order but no one has pictures of it. does anyone here have experience with one? Also I am pretty sure all I need are the discs/plates that the points mount to. they are attached with a copper braid the has come loose. is there a fix for this or does any one have parts availability? I have finally gotten back to the garage and working on the car. Thanks in advance for any help
dr914@autoatlanta.com |
Mar 12 2020, 10:40 AM
914 Guru Group: Members Posts: 7,856 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
all of the parts are available but sparingly:
points plate dist shim kit trigger points cap rotor condenser clips and screws dist o ring advance weight springs dist vacuum advance so you can rebuild yours easily enough. and if all hope is lost we have PLENTY of used ones here hello again my fellow 914 enthusiasts it has been several years since I have visited or posted. any who I am trying to find a replacement distributor for my 2.0L it is D-jet equipped and I had found that the 039-905-205 A/B/AX have all been discontinued with no parts. I have com across an AU that is special order but no one has pictures of it. does anyone here have experience with one? Also I am pretty sure all I need are the discs/plates that the points mount to. they are attached with a copper braid the has come loose. is there a fix for this or does any one have parts availability? I have finally gotten back to the garage and working on the car. Thanks in advance for any help |
Brasil914 |
Mar 12 2020, 10:47 AM
all of the parts are available but sparingly: points plate dist shim kit trigger points cap rotor condenser clips and screws dist o ring advance weight springs dist vacuum advance so you can rebuild yours easily enough. and if all hope is lost we have PLENTY of used ones here hello again my fellow 914 enthusiasts it has been several years since I have visited or posted. any who I am trying to find a replacement distributor for my 2.0L it is D-jet equipped and I had found that the 039-905-205 A/B/AX have all been discontinued with no parts. I have com across an AU that is special order but no one has pictures of it. does anyone here have experience with one? Also I am pretty sure all I need are the discs/plates that the points mount to. they are attached with a copper braid the has come loose. is there a fix for this or does any one have parts availability? I have finally gotten back to the garage and working on the car. Thanks in advance for any help where can I get them or find there part numbers the AA site doesn't even have a list number for the plates |
Lo-Fi Version | Time is now: 14th May 2024 - 04:56 PM |
