Oil Leaks, 15 of 16 plugged - should I use RTV? |
ctc911ctc |
Mar 14 2020, 07:31 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Teeners!
I redid all of the pushrod tubes and the valve covers (did the oil cooler gaskets earlier - with the Engine In!!!). Of the pushrod tubes all seem tight with the exception of Cyl 1 Exhaust!. UGH The others seem pretty tight - ran the car for 15 min at 30-40 mph prior to inspecting. Some of the others: Question is what do you do if there is a leaky tube? I will replace the tube (i have a few new ones) with new vitron gaskets, however, should I get out the RTV????? Thanks! Should start a thread called: What dis you do TWICE today to your 914? Attached image(s) |
Highland |
Mar 14 2020, 08:41 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I think the old advice from J. Raby was to use Loctite 565 on the O-rings.
That's what I did, but don't know if that's still the most current recommendation. |
r_towle |
Mar 14 2020, 08:50 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
you pinched the rubber, I can see it.
There was a time that when we ordered the seal kit, the inners were the wrong dimension and it never did get resolved. Then you would have to order the correct inners separately. Not sure if that is still the case. You id pinch it, and using vaseline when installing them helps, plus twisting as you push them in. |
ctc911ctc |
Mar 14 2020, 08:55 PM
Thanks!
I will remove and report as to the pinch, might get some Gorilla Snot to assist in the seal! you pinched the rubber, I can see it. There was a time that when we ordered the seal kit, the inners were the wrong dimension and it never did get resolved. Then you would have to order the correct inners separately. Not sure if that is still the case. You id pinch it, and using vaseline when installing them helps, plus twisting as you push them in. |
aharder |
Mar 14 2020, 09:00 PM
Advanced Member Group: Members Posts: 4,391 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
I think the old advice from J. Raby was to use Loctite 565 on the O-rings. That's what I did, but don't know if that's still the most current recommendation. interesting comment on the 565, It's a thread sealant that cures with the absence of air. Would how it would effect the removal process. (IMG:style_emoticons/default/confused24.gif) |
r_towle |
Mar 14 2020, 09:06 PM
I never use sealant, and some use RTV.
All up to you. I know it takes patience to get them in right, and lube, and twisting. |
r_towle |
Mar 14 2020, 09:08 PM
given your signature, you have it bad sir!
been playing with them since what....1972? Good for you. Feel free to reach out if you need things, I may have them. Rich |
ctc911ctc |
Mar 14 2020, 09:32 PM
Mikey914 |
Mar 14 2020, 10:51 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have some prototypes
Drop me a PM if you want to test them. Mark |
Mikey914 |
Mar 26 2020, 11:29 AM
How are these holding up?
ctc911ctc |
Mar 26 2020, 06:46 PM
How are these holding up? All, I received the new higher quality new-and-improved pushrod tube seals from 914Rubber. I had one that was a bit of trouble. Matt sent an engineering model and I installed after fanatically prepping the holes and put them in. I heard the POP! Never have had the experience where you KNOW that they are seated. I had 15 that were not leaking and one problem child. The new seals (he sent tubes too) seem to do the trick! Thank you 914 Rubber! Just put 20 miles on the car (IMG:style_emoticons/default/driving.gif) back on the rack and NO leaks! Yea! |
Lo-Fi Version | Time is now: 17th May 2024 - 03:40 PM |
