FS: 32/36 DFAV Weber Carb , Runners, etc., ..2 barrel single carb |
Literati914 |
Mar 16 2020, 01:10 PM
Senior Member Group: Members Posts: 1,456 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I don't know the history or anything about this carb or these in general, except what I'm seeing on this set. on the body it reads: "32/36DFAV23A", "MADE in SPAIN". It may works as is or it may need a rebuild. Includes intake runners (w/holes for ALL type 4 heads), boots and NEW 1.7/1.8 intake gaskets, a filter lid but no bottom plate for filter (or filter itself) - what you see is what you get.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.postimg.cc-7222-1584385802.1.jpg) |
Literati914 |
Mar 22 2020, 12:25 PM
Price Drop bump.. $75 shipped
JamesM |
Mar 22 2020, 01:01 PM
Senior Member Group: Members Posts: 1,895 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
FYI,
Any time i get one of these single carb setups on a parts car, the best luck I have had selling them is on ebay. Many 914 owners (myself included) tend to avoid them like the plague. Price wise i dont think you are far off, issue is just finding the right buyer.. GLWTS |
Literati914 |
Mar 22 2020, 01:35 PM
... Many 914 owners (myself included) tend to avoid them like the plague. GLWTS Thanks for putting that out there (IMG:style_emoticons/default/pray.gif) .. now anyone considering buying these will have this negative opinion of yours, echoing in their heads. Some folks do run these on a 914 w/ success btw. Not sure why people feel the need to comment in FS adds but you might consider just sending a PM next time. BTW - these set ups are also a good option for using on an engine stand, for testing. Still For Sale. . |
Al Meredith |
Mar 22 2020, 05:30 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Correct, I always use the 32/36 setup on my engine stand . Easier to install than duel carbs and I only want to check for oil pressure and leaks. Also easy to time the distributor . Those long runners will freeze in no time . I use metal gaskets so they heat up off the heads quicker.
Literati914 |
Mar 22 2020, 07:55 PM
Correct, I always use the 32/36 setup on my engine stand . Easier to install than duel carbs and I only want to check for oil pressure and leaks. Also easy to time the distributor . Those long runners will freeze in no time . I use metal gaskets so they heat up off the heads quicker. ..cool, so the purchaser will have intake gaskets waiting for his/her permanent set up (IMG:style_emoticons/default/smilie_pokal.gif) |
914bub |
Mar 22 2020, 08:06 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
So you haven't looked into the carb at all? Are the throttle shafts loose? Are the venturis tight? I was considering buying it for another application but with no more info...... (IMG:style_emoticons/default/confused24.gif)
Literati914 |
Mar 22 2020, 08:16 PM
So you haven't looked into the carb at all? Are the throttle shafts loose? Are the venturis tight? I was considering buying it for another application but with no more info...... (IMG:style_emoticons/default/confused24.gif) I know nothing about carbs, never messed with them.. thought I'd post a low enough price that one would considered them a core for rebuild. I lowered the price today too, btw. |
914bub |
Mar 22 2020, 08:21 PM
Cool, OK thank you!
Literati914 |
Mar 26 2020, 09:07 PM
Sold. thx.
Lo-Fi Version | Time is now: 6th May 2024 - 07:34 PM |
