Porcado restoration - 64K Porsche 914 |
Bart.Car-Bone |
Mar 18 2020, 02:59 AM
Newbie Group: Members Posts: 13 Joined: 22-January 20 From: Poland Member No.: 23,853 Region Association: None |
Hi Guys,
Just recently received mine first Porsch and it is 914 haha. Bought it very very cheap as it cost 1,5k USD in overall, a bit by mistake as it was an auction and I did not thought it will go like that. Nevertheless I am up to restoring the car. I know its original paint is 64K and during the car life it was repainted. Hence the project name PORsche avoCADO It was a barn find, and was a house for mice for long time so 1st was to clean as much as possible to reduce the smell. Now the interior is out I put the car on the jack stands to take the wheels of and put some newer tires that can be inflated. I know there is issue with hell hole. When car stands on tire the door gap is pretty uniform and roof goes easily. But when putting the car on jacks I noticed it flex mostly on the right side (saw by door gap change during lifting) well that happens when the longs are half invisible. Already purchased the 914 Left Rocker Panel Kits (L&R) from restoration design and will look into more when the car be sand blasted. My question is: were the Frame stiffener, left overlays longitudinal OEM mounted parts on the longitudinal or it is a part that we add just to make the car more stiffer (or add the stiffness to old chassis) ? Here is photo folder: PORCADO Photos |
911GT2 |
Mar 18 2020, 03:49 AM
Member Group: Members Posts: 195 Joined: 2-March 11 From: The Netherlands Member No.: 12,773 Region Association: Europe |
I think this thread will help you a lot!
But that's a lot of work mate! Hope you're not doing it on the street like these pics suggest. |
Bart.Car-Bone |
Mar 18 2020, 04:28 AM
THX,
It is waiting for wheels and until we have free space in garage to put it on the lift and for the rotisserie. Until that it is outside but the weather is good for striping the car of the parts (IMG:style_emoticons/default/biggrin.gif) |
doug_b_928 |
Mar 18 2020, 07:17 AM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
My question is: were the Frame stiffener, left overlays longitudinal OEM mounted parts on the longitudinal or it is a part that we add just to make the car more stiffer (or add the stiffness to old chassis) ? Others more knowledgeable than me will chime in, and I could be wrong, but my understanding is that the overlays were not an OE item. I'm cutting my longs to weld in patches and then sleeving on the inside to get the strength back. |
IronHillRestorations |
Mar 18 2020, 08:35 AM
The frame stiffeners do indeed overlay the outside of the longitudinals, but you have to remove the sills and the triangular brackets, as well as open up the seam on the rear jamb to get it in place.
Bart.Car-Bone |
Mar 18 2020, 09:46 AM
Well the car will be stripped and sand blasted and than all repairs will carry on hence I am thinking on overlays - if they are needed and how much they add besides extra $$
dr914@autoatlanta.com |
Mar 18 2020, 10:19 AM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I designed those as an overlay for cars so rusty that they were not worth spending hundreds of hours repairing. They can also be used to stiffen the car, but really not necessary if you repair the car properly, and I would not install them
Hi Guys, Just recently received mine first Porsch and it is 914 haha. Bought it very very cheap as it cost 1,5k USD in overall, a bit by mistake as it was an auction and I did not thought it will go like that. Nevertheless I am up to restoring the car. I know its original paint is 64K and during the car life it was repainted. Hence the project name PORsche avoCADO It was a barn find, and was a house for mice for long time so 1st was to clean as much as possible to reduce the smell. Now the interior is out I put the car on the jack stands to take the wheels of and put some newer tires that can be inflated. I know there is issue with hell hole. When car stands on tire the door gap is pretty uniform and roof goes easily. But when putting the car on jacks I noticed it flex mostly on the right side (saw by door gap change during lifting) well that happens when the longs are half invisible. Already purchased the 914 Left Rocker Panel Kits (L&R) from restoration design and will look into more when the car be sand blasted. My question is: were the Frame stiffener, left overlays longitudinal OEM mounted parts on the longitudinal or it is a part that we add just to make the car more stiffer (or add the stiffness to old chassis) ? Here is photo folder: PORCADO Photos |
Cairo94507 |
Mar 18 2020, 10:25 AM
Michael Group: Members Posts: 9,719 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Hi Bart - Good for you. I like your enthusiasm. Get that car pulled apart and then have it blasted inside and out. Off course please make sure to brace that tub adequately before you put it on the rotisserie.
It looks like you will be doing some extensive work to restore that tub so it will be solid. If you have not already, check out all of the build threads in this site. Lots of people have been down this road with their cars and come out the other end with solid cars they can enjoy driving. Cheers, Michael (IMG:style_emoticons/default/beerchug.gif) |
Bart.Car-Bone |
Mar 18 2020, 10:35 AM
@dr914 @autoatlanta.com Thank you for explanations
@Cairo94507 well I am doing that, checking, gaining knowledge. Although we do 911 restorations for clients, I will need to do all work probably by myself (IMG:style_emoticons/default/biggrin.gif) as clients cars are more priority, but with some welding knowledge I already have should be fun project! Overall idea is to make the car solid with some tweeks like GF hoods, 1,7 to 2,1 conversion and some nice interior rework (IMG:style_emoticons/default/wink.gif) |
914_7T3 |
Mar 18 2020, 08:38 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
@Bart.Car-Bone
I know a great vendor for custom interiors and repro decals! (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/welcome.png) my friend! |
Bart.Car-Bone |
Mar 19 2020, 12:36 AM
@Bart.Car-Bone I know a great vendor for custom interiors and repro decals! (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/welcome.png) my friend! Oh Cool! When I will be on that stage will ask for a name (IMG:style_emoticons/default/lol-2.gif) |
Maltese Falcon |
Mar 19 2020, 07:34 AM
Advanced Member Group: Members Posts: 4,636 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Bart...dobry dzień !
(IMG:style_emoticons/default/welcome.png) I've seen restorations start out with worse 914s, but you are going to throw some pieniądze at this one. You have come to the right place (IMG:style_emoticons/default/smile.gif) |
Bart.Car-Bone |
Mar 26 2020, 01:16 AM
A little progress... Almost ready to take engine out but,
This little mf is just stuck and the coupler near the firewall have stripped screw.... My idea is to take engine out with those connected and once is out will be easier to use vice etc. that is the reason I tool the ball joint out so I can push it more to the rear to get some better clearance in firewall. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.ibb.co-23853-1585206977.1.jpg) |
falcor75 |
Mar 26 2020, 01:32 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
If you drain the gearbox first you can unbolt the entire sideshift console from the gearbox (there are two 17? mm nuts inside the console) and then disconnect the rod at the firewall then you get that entire shift rod out of the way before you drop the engine and gearbox.
Greetings from Sweden (IMG:style_emoticons/default/smile.gif) |
Bart.Car-Bone |
Mar 26 2020, 01:35 AM
Ohh that is a good idea! will try it today (IMG:style_emoticons/default/biggrin.gif)
Bart.Car-Bone |
Mar 27 2020, 11:17 AM
Engine is out, put I bend the shifter rod badly in this process, well Maybe someone will make it straight again.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.ibb.co-23853-1585329440.1.jpg) |
Lo-Fi Version | Time is now: 28th April 2024 - 08:53 AM |
