High speed/Torque Starter |
Bulldog9 |
Mar 21 2020, 05:00 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Hey all,
In an attempt to get better cold weather starting, and better starting in general, I'm thinking about upgrading the starter to a higher speed/torque unit. The starter I originally put in was a standard rebuilt unit and has been a slow cranker from day 1. Nothing wrong with it, but I'd like to upgrade. I remember reading about them, but cant seem to find the info now. It was 8 years ago, and as I was doing a complete rebuild, couldn't go top drawer for everything. What are you guys using/recommending now? Also, I know that the Dellorto/DRLA's dont have a traditional 'choke' but are there options being used? I dont drive the car in the snow, but would be great to drive on days when it is below freezing. |
anderssj |
Apr 7 2020, 08:04 AM
Dog is my copilot... Group: Members Posts: 1,656 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Had a Tilton hi-torque unit for a number of years, but it was problematic when hot-starting, even with the Ford starter relay mod. Switched to a 911 starter last fall and although it's heavier, it has been trouble free. FWIW, I also put a push-button starter switch in the cig-lighter hole at the same time. The car starts more reliably now than when it was new.
Starting procedure with Dells on my car has been key "on," listen for fuel pump, ~5 pumps on throttle, then hit the starter. A couple of light blips, then hold at 2k RPM for a few seconds. After that it's good to go. Only cold weather problem was at high humidity at low temps (think winter in Seattle-Tacoma area). Experienced some carb/linkage icing if driving for an hour or so at relatively constant throttle. Thought about running a temporary heating hose from heater fan towards each carb, but got transferred to VA. |
Bulldog9 |
Apr 7 2020, 01:38 PM
Had a Tilton hi-torque unit for a number of years, but it was problematic when hot-starting, even with the Ford starter relay mod. Switched to a 911 starter last fall and although it's heavier, it has been trouble free. FWIW, I also put a push-button starter switch in the cig-lighter hole at the same time. The car starts more reliably now than when it was new. Starting procedure with Dells on my car has been key "on," listen for fuel pump, ~5 pumps on throttle, then hit the starter. A couple of light blips, then hold at 2k RPM for a few seconds. After that it's good to go. Only cold weather problem was at high humidity at low temps (think winter in Seattle-Tacoma area). Experienced some carb/linkage icing if driving for an hour or so at relatively constant throttle. Thought about running a temporary heating hose from heater fan towards each carb, but got transferred to VA. Funny I was also stationed in the PNW at JBLM, now am back in VA (Puzzle Palace) Where are you located? Would love to do a group drive/meet this summer. |
Bulldog9 |
Apr 7 2020, 01:42 PM
Thanks for the feedback. I ordered the IMI unit, will report on install.
I also decided to take the plunge and add the Tangerine Cooling system to the car. Will be pulling all the tins and factory fan/cooling system off and putting the Tangerine system and starter with new stainless pushrod tubes this summer with a few other things I've wanted to change. The stock system works fine, but I've been impressed with the other Tangerine components I've used on my car (Headers/Muffler, cable throttle control, and AFG air filters, have driven the car 5 years on the current rebuild, and have wanted the cooling system for a while. It has some advantages over stock, some similarities to the Raby DTM with uniform air DOWN across each cyl uniformly while keeping stock cooler, and just looks fantastic if not unique. Chris developed and uses it on his racing 914's. At my last valve adjustment, I noticed all the pushrod tubes were rusting despite prepping/painting with ceramic header paint and 'curing' in the oven. One or two have leaked a bit as well. Chris now offers SS pushrod tubes and viton bushings, should be good to go after that. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:34 AM |
