High speed/Torque Starter |
Bulldog9 |
Mar 21 2020, 05:00 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Hey all,
In an attempt to get better cold weather starting, and better starting in general, I'm thinking about upgrading the starter to a higher speed/torque unit. The starter I originally put in was a standard rebuilt unit and has been a slow cranker from day 1. Nothing wrong with it, but I'd like to upgrade. I remember reading about them, but cant seem to find the info now. It was 8 years ago, and as I was doing a complete rebuild, couldn't go top drawer for everything. What are you guys using/recommending now? Also, I know that the Dellorto/DRLA's dont have a traditional 'choke' but are there options being used? I dont drive the car in the snow, but would be great to drive on days when it is below freezing. |
jfort |
Apr 15 2020, 11:36 AM
Senior Member Group: Members Posts: 1,135 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
I had a high torque starter on my six for many years. IIRC, it came from Australia. worked fine. but when we rebuilt the engine last year we discovered that it wore the fly wheel badly and unevenly. switched back to a regular one. Might have been my bad installation but I thought it was worth mentioning.
VaccaRabite |
Apr 15 2020, 12:48 PM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I had a high torque starter on my six for many years. IIRC, it came from Australia. worked fine. but when we rebuilt the engine last year we discovered that it wore the fly wheel badly and unevenly. switched back to a regular one. Might have been my bad installation but I thought it was worth mentioning. That is a known issue for the early hi-torque starters sold about a decade and a half ago. They needed to be shimmed with washers to get the correct engagement on the flywheel teeth or you got wear on the flywheel. Zach |
Tdskip |
Apr 15 2020, 02:19 PM
I had a high torque starter on my six for many years. IIRC, it came from Australia. worked fine. but when we rebuilt the engine last year we discovered that it wore the fly wheel badly and unevenly. switched back to a regular one. Might have been my bad installation but I thought it was worth mentioning. That is a known issue for the early hi-torque starters sold about a decade and a half ago. They needed to be shimmed with washers to get the correct engagement on the flywheel teeth or you got wear on the flywheel. Zach Is this still an issue, or is there a vendor offering that avoids this issue? |
Lo-Fi Version | Time is now: 16th May 2024 - 02:46 AM |
