| euro911 |
Mar 27 2020, 05:08 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,945 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Nice Targa, 'Goob' ( @Larmo63 ) ... pix of the Bat Cave? (IMG:style_emoticons/default/popcorn[1].gif)
@markhoward ... the front end should lower itself fine after you install the hood, grille & bumper assemblies (IMG:style_emoticons/default/laugh.gif) Cool little teardrop, Doug ( @dlee6204 ) Keep them projects coming ... |
| 9one4tay |
Mar 27 2020, 05:18 PM
Newbie ![]() Group: Members Posts: 25 Joined: 13-January 20 From: Boulder Creek, Ca. Member No.: 23,825 Region Association: Northern California |
Getting this 74' 2.0 going after a 27 year hibernation:
New gas tank New clutch kit/flywheel New engine/trans mounts New fuel pump relocated up frunk New shift bushings New vacuum lines Rebuilt distributor/electronic ignition Tangerine Racing ss fuel lines and lots of other small bits Looking to buy a 2.0 ECU mounting Bracket if anyone has one Travis Attached image(s)
| Betty |
Mar 27 2020, 09:13 PM
Driver ![]() ![]() ![]() Group: Members Posts: 523 Joined: 10-December 04 From: Hurst, TX Member No.: 3,255 Region Association: South East States
Been putting the finishing touches on my teardrop trailer. I just have some headliner material to install on the interior and then it’ll be ready. I built everything from scratch. Aluminum trailer and the body is all foam. The entire thing weighs 200-300 lbs. I built it to tow behind anything. More pictures? Interior too? (IMG:style_emoticons/default/smilie_pokal.gif) |
| markhoward |
Mar 27 2020, 09:39 PM
Member ![]() ![]() Group: Members Posts: 409 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California
Nice Targa, 'Goob' ( @Larmo63 ) ... pix of the Bat Cave? (IMG:style_emoticons/default/popcorn[1].gif) @markhoward ... the front end should lower itself fine after you install the hood, grille & bumper assemblies (IMG:style_emoticons/default/laugh.gif) Cool little teardrop, Doug ( @dlee6204 ) Keep them projects coming ... It did settle some but the few hunid pounds off the front is definitely showing. @dlee6204 , looking forward to those interior shots.. |
| djway |
Mar 28 2020, 12:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Heard a Dr. on TV saying in this time of Coronavirus staying at home we should focus on inner peace. To achieve this we should always finish things we start and we all could use more calm in our lives. I looked through my house to find things I’d started and hadn't finished, so I finished off a bottle of Merlot, a bottle of Chardonnay, a bodle of Baileys, a butle of wum, tha mainder of Valiumun srciptuns, an a box a chocletz. Yu haf no idr how feckin fablus I feel rite now. Sned this to thuzl who need inner piss. An telum u luvum. And two hash yer wands, stafe day avrybobby!!! The Dude Abides |
| porschetub |
Mar 28 2020, 04:33 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,188 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Finishing some odd jobs on my house which is now on the market,one reason for selling is it is very isolated ,however that is sadly an advantage now as we are locked down.
Any work is limited as I can't buy materials except online which is a real PITA. Repaired my old faithful Bosch 5" angle grinder as I'am fitting a towbar to my VW T4 Tranporter van,for some reason the towbar was missing except for the bolt on chassis plates but all the wiring was tucked up under the bumper so at least I don't have to do that (IMG:style_emoticons/default/biggrin.gif) . Will see how I go but may move the 914 home from storage and do outstanding overdue jobs. Keen to do more work but my head space is wrong,anyway got to pass the time somehow,we have 1 month I strongly suspect it may be extended (IMG:style_emoticons/default/sad.gif) . |
| 914forme |
Mar 28 2020, 07:22 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
Since the Virus does not like heat or UV-3, I figured what would make me the safest guy on the planet.
Some welding, so out came the TIG and MIG, and we started to weld, and weld, and weld some more. First thing I did was weld up a gantry crane, we had one at the farm shop for years I forgot how handy they are for everyday tasks. IT is still not ready for prime time pictures but I pressed it into service today, lifting some gas cylinders, righting a tool box I had on its side wot weld up a ZTFab welding cart. Of course I could not leave well enough alone, and decided to change the mounts for the axles so they have a bit more meat to hold them true. And then I don't like safe chains as my main way of keeping a bootle on the cart, so I took some bottle wall mounts, and fabricated a mount so they work on the cart. I got them from my welding supplier they were 17, and 22 respectfully, less than the cost for me to fabricate them. Bottles going no where. Everything loaded up on the US General tool cabinet. I used to have all of this on two craftsmen boxes. They will be repurposed for a bench I am building. Next I picked up a quick jack right before our governor tossed us into lock down. Paid $500 for the 7000 lbs version. Issue is it is not easy to move. So I saw an idea on the internet, and I decided it was to complicated. I had these from an outfield stand, and well they never out feed correctly, and two I am using them to support long picks of tube and steel so I can fixture on the welding bench. So I had a bunch of them. Mounted them to the lift arms, so that when it comes down the weight of the lift is a fulcrum and the wheels will lift the bottom of the lift up about 1/4" Now it is easy to move around the shop. Thats all for today, hopefully get back out tomorrow go through stuff and cleanup a bit. Need to get lawn equipment in for service, and winter tires off the 7 series. (IMG:style_emoticons/default/piratenanner.gif) Means I can (IMG:style_emoticons/default/driving.gif) like I like to. Attached thumbnail(s) |
| euro911 |
Mar 29 2020, 01:53 PM
I guess I could have posted this in either the 'shelter me' or 'not working on the 914' threads (IMG:style_emoticons/default/unsure.gif)
The Ghia died a few months ago and had it 'AAA'd' home for diagnosis. After testing different components, found the root cause to be a worn out ignition switch. Digging through the rat's nest of wiring behind the dash made it apparent that this was not it's first rodeo (due to all the butt connectors found). Not only had the electrical portion of the switch fail, but the tumbler assembly would not stay in the barrel and came out with the key at times, so I purchased both new components last month. Yesterday, I replaced the switch components and wired into the harness, and made some minor repairs to the instrument cluster in the speedo (the lower lamp assembly wouldn't stay in it's socket, so I secured it in place with liquid tape) ... and re-inserted the other lamp sockets that had become dislodged during my poking around in there (IMG:style_emoticons/default/dry.gif) It was also missing the lower dash/knee pad, so I had ordered a new EMPI pad when I ordered the switch stuff. My wife assisted, holding the pad in place whilst I crawled into the trunk to attach the washers & nuts - which was a royal PITA. I have the scars on my arms and hands to prove it (IMG:style_emoticons/default/laugh.gif) Reinstalled the new turn signal switch (that I replaced a couple months ago) and the steering wheel just before nightfall. In any event, everything worked out OK ... and if the battery still has enough oomph, I'll see if it'll start up today (IMG:style_emoticons/default/popcorn[1].gif) |
| Daryl32 |
Mar 29 2020, 03:29 PM
Member ![]() ![]() Group: Members Posts: 133 Joined: 14-January 20 From: Southern California Member No.: 23,827 Region Association: Southern California |
I have a garage full of 1/24th and 1/10th scale projects to keep me busy.
Just not sure where to start. They all need cleaning the playing with! (IMG:style_emoticons/default/piratenanner.gif) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| tygaboy |
Mar 29 2020, 03:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,858 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
I made not quite matching "his & hers" computer stands for use with our smart trainers.
Nice to be able to find a use for a few roll cage left overs! Attached thumbnail(s) |
| mepstein |
Mar 29 2020, 04:33 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,930 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I made not quite matching "his & hers" computer stands for use with our smart trainers. Nice to be able to find a use for a few roll cage left overs! OK, now I'm jealous. (IMG:style_emoticons/default/smilie_pokal.gif) |
| ClayPerrine |
Mar 29 2020, 06:22 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I spent Saturday and Sunday replacing the exhaust manifold on my Jeep Comanche.
I replaced the exhaust manifold with the broken stud with a header. They moved the O2 sensor bung to the other side of the truck, so I had to strip the harness and move the wires for the O2 sensor to run down the right side of the bell housing. The pictures are me sitting in the engine compartment removing the electrical tape from the harness. ![]() Turns out the EGR tube twisted off the threads on the fitting for the mainfold side of the tube. I braved the outside world, and bought some steel rod. I used it to make 2 pipe plugs (Nothing is available in M22x1.5 at our local Ace hardware). I own a M22x1.5 die, so I threaded the rod, then cut it off and ground a 13mm section on the end so it had square flats on it. I screwed them into the EGR connection on the bottom of the mainfold, and into the header's EGR port. This will have to do until I can get the right fitting to replace on the end of the old EGR tube. I put everything back together. In the process I found out the header now blocks one bolt that holds both the header and the intake manifold to the head. I dropped that ^$%@%$^%@ bold 28 times (Yes, I was counting) before I finally got it started. I had to tighten it from the bottom with an open end wrench. Dropped the wrench a few times, one right smack in the center of my forehead. (IMG:style_emoticons/default/blink.gif) I am tired, bloody and battered. But the exhaust leak I had is now fixed. (IMG:style_emoticons/default/smilie_pokal.gif) |
| mepstein |
Mar 29 2020, 07:10 PM
Hi Rory I restored a rare early 914-6 drivers seat adjuster. These are the straight arm style with different knob and brass adjustment finger. I’m saving my HO train build for retirement I had forgotten there was an early version. I'll have to check my '70 four that I'm parting out. Ok. Found one. I might have more but that would require more digging. It’s not as pretty as yours. Attached image(s)
| mbseto |
Mar 30 2020, 11:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,257 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Re-stocking a 30's era Mauser. I have a few gun cleaning projects to do as well, wish our range was open!, and I spy that Buffalo trace and a Blanton's!! so far I only have 4 of the Blanton tops, not available here in SC I have to grab those when I go to NC to see my son or up to Cincy to see the nephew and their kids. in fact just to get a Buffalo trace I had to get on a list during holiday and they got an allocated shipment and they called me to pick up my bottle! crazy how different availability of bourbon differs from state to state!!;- so enjoy and have a shot for me. I know you are in Cincy, as is my nephew, so you guys have way better access for that and other Buffalo trace and Stitzle-Weller products! My fav is the Weller Antique 107, but I did have some Pappy this past Weekend!!!!! - heard it kills viruses if the proof is over 120 (IMG:style_emoticons/default/biggrin.gif) Good eye, @DRPHIL914 . Buffalo Trace has been tricky to find here since their little warehouse scandal. Not sure if that was the cause. But my kid has been going to school down near Nashville, so when I go to visit I must drive a good portion of the bourbon trail. Just trying to be a good dad. South of Louisville they are never out of anything and the prices are about 15-20% better than here, so I make sure to stock up. I'll drink to your health! |
| mb911 |
Mar 30 2020, 01:02 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,816 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
| theer |
Mar 30 2020, 01:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States
Hi Rory I restored a rare early 914-6 drivers seat adjuster. These are the straight arm style with different knob and brass adjustment finger. I’m saving my HO train build for retirement I had forgotten there was an early version. I'll have to check my '70 four that I'm parting out. Ok. Found one. I might have more but that would require more digging. It’s not as pretty as yours. I have one, too from an early (1970) parts car. Mine is more like Mark's in terms of condition. |
| euro911 |
Mar 30 2020, 01:59 PM
The remodel looks great, Ben. What did your basement look like before?
| mb911 |
Mar 30 2020, 02:29 PM
The remodel looks great, Ben. What did your basement look like before? @euro911 it was just bare concrete.. We moved in the 21st of January this year and got all this done in short order.. |
| North Coast Jim |
Mar 30 2020, 04:15 PM
Member ![]() ![]() Group: Members Posts: 349 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region
Went to Home "Projects" again today. I'm surprised at the amount of paint flying off the shelves. The couples buying it have the female with a big smile and the male partner with a frown on his face. I buy nothing but guaranteed "10 year" paint. No color changed allowed during that period. Ha Ha
| 913B |
Mar 30 2020, 10:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Since the Virus does not like heat or UV-3, I figured what would make me the safest guy on the planet. Some welding, so out came the TIG and MIG, and we started to weld, and weld, and weld some more. First thing I did was weld up a gantry crane, we had one at the farm shop for years I forgot how handy they are for everyday tasks. IT is still not ready for prime time pictures but I pressed it into service today, lifting some gas cylinders, righting a tool box I had on its side wot weld up a ZTFab welding cart. Of course I could not leave well enough alone, and decided to change the mounts for the axles so they have a bit more meat to hold them true. And then I don't like safe chains as my main way of keeping a bootle on the cart, so I took some bottle wall mounts, and fabricated a mount so they work on the cart. I got them from my welding supplier they were 17, and 22 respectfully, less than the cost for me to fabricate them. Bottles going no where. Everything loaded up on the US General tool cabinet. I used to have all of this on two craftsmen boxes. They will be repurposed for a bench I am building. Next I picked up a quick jack right before our governor tossed us into lock down. Paid $500 for the 7000 lbs version. Issue is it is not easy to move. So I saw an idea on the internet, and I decided it was to complicated. I had these from an outfield stand, and well they never out feed correctly, and two I am using them to support long picks of tube and steel so I can fixture on the welding bench. So I had a bunch of them. Mounted them to the lift arms, so that when it comes down the weight of the lift is a fulcrum and the wheels will lift the bottom of the lift up about 1/4" Now it is easy to move around the shop. Thats all for today, hopefully get back out tomorrow go through stuff and cleanup a bit. Need to get lawn equipment in for service, and winter tires off the 7 series. (IMG:style_emoticons/default/piratenanner.gif) Means I can (IMG:style_emoticons/default/driving.gif) like I like to. I like your roller bearing hack on the QJ. Can I ask you a few questions if you don't mind? Approximately how far from the hole did you install the bearing? Also is there a nut holding the screw inside the QJ rail, probably not I am thinking. Did you use a self-tapping screw or maybe you made some threads in the bar to screw it in. Sorry for all the questions. I found an inexpensive equivalent from harbor freight and thought this would make moving the QJ around easier. Thank you for your input. Ted |
Lo-Fi Version | Time is now: 13th October 2026 - 06:23 PM |
