Brake Fluid Flood at Pedal Cluster |
Mikey914 |
Mar 23 2020, 02:18 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Thanks for the props guys.
Bleeding the MC can be an issue with a pressure bleeder if you crank up the pressure. The best way is by vacuum https://www.harborfreight.com/Brake-Bleeder...nRoCIK4QAvD_BwE |
Lo-Fi Version | Time is now: 26th May 2024 - 10:02 AM |
