Front wing / windscreen scuttle gap |
dt4 |
Mar 23 2020, 07:14 AM
Senior Member Group: Members Posts: 502 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
Mar 23 2020, 07:17 AM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
It gets a "T" shaped rubber seal.
Installed after paint. |
injunmort |
Mar 23 2020, 07:18 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
there is a rubber molding that fits into the gap
dt4 |
Mar 23 2020, 07:43 AM
dt4 |
Mar 23 2020, 07:44 AM
next question (IMG:style_emoticons/default/smile.gif)
any body got...………..? |
dr914@autoatlanta.com |
Mar 23 2020, 07:56 AM
914 Guru Group: Members Posts: 7,838 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we call them fender dividers, factory first welded the joint on the prototypes, but decided for future repair would be best to leave a gap for easier fender removal without hurting the cowl.
By the way, you will have to replace those windshield clips if you even hope to have the anodized molding clip back in. Sad but true, you will have to remove the windshield |
Mar 23 2020, 08:06 AM
FlacaProductions |
Mar 23 2020, 08:12 AM
Senior Member Group: Members Posts: 1,570 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
dt4 |
Mar 23 2020, 09:14 AM
@mepstein @injunmort thank you, that makes sense, it looks very unfinished without anything in there, I will make sure it remains clear of paint so the moulding fits The gap must be painted. I would get a seal and check fit. 914rubber, etc carry them for a couple dollars. I meant not clogged / filled with paint, now I know there is a moulding I will get the pair to check for fit cheers |
dt4 |
Mar 23 2020, 09:20 AM
£10 each in the UK
https://www.design911.co.uk/fu/prod138744/P...mp;utm_content= Dick Turpin is alive and well (look him up (IMG:style_emoticons/default/smile.gif) ) How does than compare to US prices |
Mar 23 2020, 09:23 AM
$4 each. It’s fine to use used if you can find them. It’s more of a trim piece than a seal that keeps water out.
dt4 |
Mar 23 2020, 09:27 AM
I'll check in with stateside suppliers, I would sooner spend £20 with Mark or George than the thieving fu%&ers over here
Mar 23 2020, 09:34 AM
And like George said, put a windshield kit on your list. I think it’s about 19 clips and 2 spacers.
Mark Henry |
Mar 23 2020, 09:56 AM
I don't have the seals, IMHO they are a dirt and moisture trap.
Just pulled the seals on the wife's 914, (6 yr/old resto by PO) I'm correct on the dirt trap part. I'm going to wrap the wife's car, I might reuse the seals when done wrapping. |
Mikey914 |
Mar 23 2020, 10:01 AM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The ones I made are rubber, not like the OEM. They are a PVC. I did this so that they could easily be removed cor cleaning, and not get hard and brittle.
Makes cleaning easier. (IMG:style_emoticons/default/biggrin.gif) |
dt4 |
Mar 23 2020, 01:42 PM
Mar 23 2020, 01:55 PM
And like George said, put a windshield kit on your list. I think it’s about 19 clips and 2 spacers. thanks mepstein so they arent "reusable" ? I have had the trim off and on again a couple of times I've never been able to get a windshield out without breaking a couple so for me they are not reusable. I believe it's recommended to replace but it's probable the case that not everyone does. |
aturboman |
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
You can always lead them in for a nice clean look.
Like George said that was how the factory intended them to be originally until the accountants took the project over. |
roblav1 |
Mar 23 2020, 01:56 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
As I wrote on another post, I tig them and grind flat on my cars. They are water / crud resevoirs.
dt4 |
Mar 23 2020, 02:11 PM
I dont have the tig kit but i could lead load, if Mark is able to supply I will go OE first
back to the trim clips around the windshield, I removed the trim without breaking any and the glass is staying in place as there was enough space to get the wire wheel in around the glass to remove the paint far enough back for repainting so I was working on them being reusable. I refitted the trim when it came back from polishing to check it had not been deformed and it seemed to clip home ok. |
Lo-Fi Version | Time is now: 7th May 2024 - 10:34 AM |
