Early hand brake spring, is this broken or not ? |
rgalla9146 |
Mar 23 2020, 11:40 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Is the flat spring in this handle intact ? The tip feels very smooth, not broken.
I have two of these handles in 1970 cars and both require a very curious motion to engage and release. I have seen this flat part completly broken off. Is this one intact ? Attached thumbnail(s) |
dr914@autoatlanta.com |
Mar 23 2020, 11:41 AM
914 Guru Group: Members Posts: 7,850 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
no but looks bent, the new rod with tension spring are readily available, just not the complete early handbrake assembly
Is the flat spring in this handle intact ? The tip feels very smooth, not broken. I have two of these handles in 1970 cars and both require a very curious motion to engage and release. I have seen this flat part completly broken off. Is this one intact ? |
rgalla9146 |
Mar 23 2020, 01:46 PM
no but looks bent, the new rod with tension spring are readily available, just not the complete early handbrake assembly Is the flat spring in this handle intact ? The tip feels very smooth, not broken. I have two of these handles in 1970 cars and both require a very curious motion to engage and release. I have seen this flat part completly broken off. Is this one intact ? So.....which is it ? No, it's not broken or No, it's not intact My coil spring is fine. A new rod for the early handle is available ? A reliable source ? |
mepstein |
Mar 23 2020, 01:51 PM
914-6 GT in waiting Group: Members Posts: 19,264 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
no but looks bent, the new rod with tension spring are readily available, just not the complete early handbrake assembly Is the flat spring in this handle intact ? The tip feels very smooth, not broken. I have two of these handles in 1970 cars and both require a very curious motion to engage and release. I have seen this flat part completly broken off. Is this one intact ? So.....which is it ? No, it's not broken or No, it's not intact My coil spring is fine. A new rod for the early handle is available ? A reliable source ? Carpoint has them - https://www.carpoint.de/ersatzteile/origina...__from_store=fr |
rgalla9146 |
Mar 23 2020, 02:10 PM
no but looks bent, the new rod with tension spring are readily available, just not the complete early handbrake assembly Is the flat spring in this handle intact ? The tip feels very smooth, not broken. I have two of these handles in 1970 cars and both require a very curious motion to engage and release. I have seen this flat part completly broken off. Is this one intact ? So.....which is it ? No, it's not broken or No, it's not intact My coil spring is fine. A new rod for the early handle is available ? A reliable source ? Carpoint has them - https://www.carpoint.de/ersatzteile/origina...__from_store=fr Excellent info. Thank you Mark |
Lo-Fi Version | Time is now: 13th May 2024 - 08:00 AM |
