New GB Front trunk seal lip replacement metal 4' sections, $15 / $12.50 each if you buy 2 or more GB closes the 15th - TODAY |
Mikey914 |
Mar 23 2020, 05:06 PM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So working with Cary on making a replacement metal that can be spliced in for the rusted channels that many of us have. Decided to do up a batch so that these are inexpensive for all. Cary has used these to repair my and Taylor's vehicles
You can cut out and drill spot welds to patch corners, or completely rebuild the entire trunk edge. If it's not too bad one strip should suffice, but they get cheaper if you get 2. We will also basically give you one for the shipping if you buy a new front trunk seal. The metal ships in it's own tube so if you ship USPS it should be about $8.50. I'm working with Cary to provide a little more of a tutorial on these, but now you can fix the rust!!! Who's in? Attached image(s) |
bkrantz |
Mar 23 2020, 09:12 PM
914 Guru Group: Members Posts: 7,754 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I need at least 1.
Lo-Fi Version | Time is now: 8th May 2024 - 08:09 PM |
