Turning engine over, Turning engine over |
simonjb |
Mar 23 2020, 07:23 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
I have an engine out of the car without a flywheel and no fan. I wanted to make sure it’s ok to turn the engine over without these attached. The reason I ask is that there is some front to rear play in the camshaft - which I understand is normal - but I want to make sure if I turn it over I won’t damage anything inside.
simonjb |
Mar 24 2020, 07:58 AM
Anyone out there can help here?
bdstone914 |
Mar 24 2020, 08:42 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Anyone out there can help here? No reason it will damage anything. How have you determined the excess camshaft endplay? Maybe the camshaft thrust bearing is shot. I put two bolts in the fan hub and a bar between them to turn over an engine with no fan or flywheel. |
ctc911ctc |
Mar 24 2020, 09:46 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Anyone out there can help here? No reason it will damage anything. How have you determined the excess camshaft endplay? Maybe the camshaft thrust bearing is shot. I put two bolts in the fan hub and a bar between them to turn over an engine with no fan or flywheel. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 7th May 2024 - 02:24 AM |
