Tips on pressure washing a 914 |
Tdskip |
Mar 24 2020, 09:18 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning - have some time to clean up a couple of the cars (shocking, yes) and wanted to ask about do/don’t when using a pressure washer.
Obviously not on carbs or any points of water ingress into the engine or trans, other tips? Thanks gentlemen. |
eric9144 |
Mar 24 2020, 09:31 AM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Try to avoid blasting lenses.
If there aren't rain tray's on the engine lids take a large trash bag and cover the whole engine lid with it to prevent a crap load of water getting in there. When done check both trunks for pooled water and both sides of the engine bay. Also try to avoid blasting the back window from the outside, if seals are old it tends to be the final nail in the coffin for the seal and you'll end up with lots of water in the cabin behind the seats at the base of the fire wall (inside) Depending on the nozzle you use avoid getting too close to the paint and under coating because you'll blast it right off. |
Johny Blackstain |
Mar 24 2020, 09:38 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I wouldn't pressure wash any old VW or Porsche because like it or not they're all notorious rust buckets and pressure washing tends to get water in to places it normally doesn't get. I wash by hand & then dry with a leaf blower & shammy. (IMG:style_emoticons/default/cool_shades.gif)
FlacaProductions |
Mar 24 2020, 10:05 AM
Senior Member Group: Members Posts: 1,594 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
The only place i'd use a pressure washer would be in the longs after I removed the outer rockers or - at least - removed the hardware across the bottom and pulled them out a touch so that the water and crap that you'll dislodge has somewhere to go....
TravisNeff |
Mar 24 2020, 10:16 AM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Don't get the wand too close to the paint. It can take it off if you are an inch or two away. On my 911 I have a couple of spots where the paint got thin when I was cleaning the underside (less paint is used on the bottom).
Tdskip |
Mar 24 2020, 11:27 AM
Thanks guys, appreciate the responses.
It is really the engine bay and trans, but I remember Dr Evil giving dope slaps for pressure washing the transmission. |
Lo-Fi Version | Time is now: 25th May 2024 - 01:25 PM |
