Jacking point damage? |
Biggles |
Mar 25 2020, 10:00 AM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
I've noticed that the front jacking points on my car aren't level, and wondered if they've gone up as the car has been lifted - thoughts? It all seems solid.
Attached thumbnail(s) |
SirAndy |
Mar 25 2020, 10:15 AM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
They are crooked because those aren't jacking points!
There is noting solid on the other side, using them as jacking points means you are deforming your floorpan. (IMG:style_emoticons/default/shades.gif) |
bkrantz |
Mar 25 2020, 08:29 PM
914 Guru Group: Members Posts: 7,735 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
They are crooked because those aren't jacking points! There is noting solid on the other side, using them as jacking points means you are deforming your floorpan. (IMG:style_emoticons/default/shades.gif) There is on mine (with some custom backing plates inside the front floor). Attached thumbnail(s) |
914e |
Mar 25 2020, 09:32 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
They are crooked because those aren't jacking points! There is noting solid on the other side, using them as jacking points means you are deforming your floorpan. (IMG:style_emoticons/default/shades.gif) There is on mine (with some custom backing plates inside the front floor). I thought about doing that as well. What gauge of sheet metal did you use? |
Lo-Fi Version | Time is now: 26th April 2024 - 08:14 AM |
