Rear Hub confusion, Five lugs again |
abnrdo |
Mar 26 2020, 10:57 AM
Member Group: Members Posts: 399 Joined: 24-September 04 From: Panama City, FL Member No.: 2,820 Region Association: South East States |
Do I want to buy 911SC hubs with a spacer or hubs without???
davep |
Mar 26 2020, 11:06 AM
914 Historian Group: Benefactors Posts: 5,137 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
That "spacer" is the inner race of the old bearing. You do not want that!
914werke |
Mar 26 2020, 11:09 AM
"I got blisters on me fingers" Group: Members Posts: 10,030 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
what spacer are you referring to?
The pic you provided has drilled hubs that someone has neglected to remove .5 of the split bearing that is still stuck on the shafts ? |
Mar 26 2020, 11:12 AM
914-6 GT in waiting Group: Members Posts: 19,251 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
That "spacer" is the inner race of the old bearing. You do not want that! You almost always have to remove that old inner race. Just like when you redo 914 hubs. SC and later hubs will be hub centric and need a 5mm spacer behind the bearing. Early rear hubs are lug centric and do not need the 5mm spacer. |
Mueller |
Mar 26 2020, 11:24 AM
Those races should be removed before sale IMHO.
Mar 26 2020, 11:37 AM
It’s the same with front hubs. I’ve had at least 10 sets and they always have the old races in them.
abnrdo |
Mar 26 2020, 11:50 AM
Thanks everyone, I guess I was confused. Looks like Patrick Motorsports has them for almost the same price as a good used pair.
Mar 26 2020, 02:09 PM
914Sixer |
Mar 26 2020, 04:51 PM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
If you run SC rear hubs you need the 5mm spacer they sell to put on the hub before you press in the hub. Recommend you run the 100mm SC stub axle. You can use 944 or VW Bus CV
Luke M |
Mar 27 2020, 06:03 AM
Senior Member Group: Members Posts: 1,370 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
If you run SC rear hubs you need the 5mm spacer they sell to put on the hub before you press in the hub. Recommend you run the 100mm SC stub axle. You can use 944 or VW Bus CV This is the setup I'm going to run in my 914-6 when it's done. I have the later 74-89 centric front and rear hubs w/PMS spacers ( my parts are from a 84 911 Carrera). Using modified 914 axles and new 944 100 mm 6 bolt cv joints, mid year 911 6 bolt trans output flanges and SC hub spindles. True 5 lug bolt in solution. There's some good info in the classic section as well. |
914Sixer |
Mar 27 2020, 06:43 AM
Luke's set up is what I am using on my conversion.
Lo-Fi Version | Time is now: 2nd May 2024 - 02:56 AM |
