AFR Sensor Location.... |
MikeM |
Mar 27 2020, 12:19 PM
Senior Member Group: Members Posts: 558 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...
I'm still thinking I should be using an AFR gauge in my modified and carb'd 2.0 liter. Any new thoughts or info regarding the location of the sensor? I'm using stock heat exchangers and banana muffler. I have a Bursch type exhaust as well but prefer the stock system. Also, is the PLX still the recommended system to use? Thanks in advance...and stay safe everyone. Mike |
rjames |
Mar 27 2020, 12:35 PM
I'm made of metal Group: Members Posts: 3,917 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I've been happy with my PLX unit. I only bought it last year, but no problems so far. Install was easy and they supplied plenty of wiring to reach from muffler to the dash.
I bought the bluetooth unit tucked away behind the center console and am using their mobile app on my iPhone as a gauge. |
Mark Henry |
Mar 27 2020, 01:14 PM
The absolute best would be to weld a tube between two of the runners just before the muffler flange, then weld a bung on top of the tube. Then you are running off of 2 cylinders which is enough for tuning.
Problem with running it in the muffler is it doesn't get hot enough and you won't get an accurate reading. I consistently see around a 100 degree difference between the exchanger/header and the muffler temps. |
MikeM |
Mar 27 2020, 01:16 PM
Thanks Mark...
Lo-Fi Version | Time is now: 28th April 2024 - 09:26 PM |
