Rear Rotor Removal, rusted stuck? Not Anymore!, Two Screws? |
76-914 |
Mar 28 2020, 09:36 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
[quote name='Jamie' date='Mar 28 2020, 08:09 AM' post='2798529']
[quote name='Bmw635' date='Mar 27 2020, 12:47 PM' post='2798273'] Could try this impact driver. Hammer the handle and the bit will twist in direction you want while pushing the tip in to prevent rounding. [/quote Don't overlook the fact that these impact drivers have Forward and Reverse settings. (IMG:style_emoticons/default/sunglasses.gif) [/quote] I just use the tips from the impact hammer anymore. I use them in my air impact and it works great. Just keep a lot of pressure against the screw head and keep it square. I tried to remove some large Philips head screws from a Karmann Ghia door hinge using the impact tool and did nothing more than scar a few. Got pissed off and put the bit in my 1/2" air impact wrench and Bingo they all backed out. Even the few I scarred. (IMG:style_emoticons/default/confused24.gif) |
Jett |
Mar 28 2020, 09:49 AM
Senior Member Group: Members Posts: 1,639 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Use a torch, works every time
cary |
Mar 29 2020, 12:36 AM
What Kent said ............. Impact driver bit holder slips right on your 1/2 impact
gun. Hold it tight or you'll break off the bit. One little blip is usually enough. |
cassmcentee |
Mar 29 2020, 11:11 AM
Member Group: Members Posts: 180 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California |
Heated the surrounding area to Red
Hit the screw with a 6mm socket With calm pressure used a Makita impact gun with the proper bit Screws came right out without scars! Easy Peasy! Didn't have any 8mm bolts handy Used gentle hammering on the rotor till she budged a wee bit sprayed the exposed gap with PB Some more gentle taps and Whalla! Off they came Thank you for the help! Sincerely, Cass |
Solocholo |
Sep 9 2021, 09:16 AM
Newbie Group: Members Posts: 7 Joined: 20-July 21 From: California Member No.: 25,739 Region Association: Southern California |
Ya my bolt that holds the rotor on is stuck too? Broke two 1/2 drives, and a 4 foot breaker Pipie, now the rotor is stuck too, this car has been sitting 30 years,
Lo-Fi Version | Time is now: 21st May 2024 - 05:33 AM |
