Brain Trust Needed - 2L Refresh |
yeahmag |
Mar 28 2020, 11:01 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
This might be long...
My current combo runs great, but I've been sitting on a set of Finch heads from Len Hoffman for years. There is no racing right now, so it seems like a good time. Here is the current combo: 2056cc Stock Rods Stock 2L heads (match ported) 86a Cam 9.5:1 I got a set of JE pistons in another deal (brand new, 96mm) and they appear to be stroker pistons. By my calculations I'd only need a 5.294" rod to counter the reduced pin height and am planning on a 5.325" rod or longer. Should be good either way there. Now for the big problem. The Finch heads have a 50cc step-cut chamber. I like to run a tight deck (.04") and that combo would put me at 10:1. To get to the 9.5:1 I've been running I'd need to run almost .06" deck height. So three questions. 1. Can the 86a handle 10:1 on 91 pump gas with proper tuning? 2. Is it better to run a loose deck and keep it at 9.5:1? 3. Put a 2cc (or larger) dish in the piston tops to keep a tight deck and lower the CR to 9.5:1 which I know works? Thanks! -Aaron |
larryM |
Mar 28 2020, 07:35 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
10:1 on 91 gas is a daydream - some get away with it on iron engines, but no way is is "safe" on alu engines
you can buy a MSD or other gadget to dial back the timing, but doing so simply results in no better performance than y'd get by sticking with your current CR . . . if it's just a race car - go for the max, understanding that you will frequently rebuild the motor in your quest for the trophy - that's how "real racers" look at it - $$$ & longevity are irrelevant |
Lo-Fi Version | Time is now: 16th May 2024 - 03:27 AM |
