Brain Trust Needed - 2L Refresh |
yeahmag |
Mar 28 2020, 11:01 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
This might be long...
My current combo runs great, but I've been sitting on a set of Finch heads from Len Hoffman for years. There is no racing right now, so it seems like a good time. Here is the current combo: 2056cc Stock Rods Stock 2L heads (match ported) 86a Cam 9.5:1 I got a set of JE pistons in another deal (brand new, 96mm) and they appear to be stroker pistons. By my calculations I'd only need a 5.294" rod to counter the reduced pin height and am planning on a 5.325" rod or longer. Should be good either way there. Now for the big problem. The Finch heads have a 50cc step-cut chamber. I like to run a tight deck (.04") and that combo would put me at 10:1. To get to the 9.5:1 I've been running I'd need to run almost .06" deck height. So three questions. 1. Can the 86a handle 10:1 on 91 pump gas with proper tuning? 2. Is it better to run a loose deck and keep it at 9.5:1? 3. Put a 2cc (or larger) dish in the piston tops to keep a tight deck and lower the CR to 9.5:1 which I know works? Thanks! -Aaron |
yeahmag |
Mar 31 2020, 04:50 PM
I'm running a set of 40 Dellorto's, but with 36mm vents in them. I'm also running a Mallory Unilite, Mallory 6AL, and an LM-2, so I have tools do do some tuning. I have a 123 ignition on the shelf, but it needs some mods to work. Not out of the question though.
I have pretty much decided to put a 3cc dish in the pistons and run 5.325" rods from EMW. That should put my CR where I need it and allow me to not split the case at this time. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:33 PM |
