Factory 914-6 engine mount clearance issue?, When used on a 3.2 or 3.6 |
Luke M |
Mar 29 2020, 06:50 AM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Thinking of getting a 3.2 or a 993 3.6. If using the factory 914-6 engine mount will I run into any clearance issues around the crank pulley area?
I know of a few other issues that I may encounter. For you 3.2 and 3.6 guys out there any words of wisdom before I jump into this? |
rgalla9146 |
Mar 29 2020, 07:14 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Never done it but understand pully has to be changed which elimenates
accessory drive ? |
Mark Henry |
Mar 29 2020, 08:01 AM
Never done it but understand pully has to be changed which elimenates accessory drive ? AC pulley won't work without major mods, find a single pulley with the same fan drive size. IIRC any air cooled pulley will work but there's a few different sizes of the crank pulley and then there's a couple different sizes of the fan pulleys. Do a search on pelican, there was a list of the different sizes. I went with the SC sized pulleys on the right , I can just sneak the belt past the tin, would be a PITA to change the belt in car without my big access hole. (IMG:http://www.914world.com/bbs2/uploads/post-26-1391692879.jpg) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:47 AM |
