Factory 914-6 engine mount clearance issue?, When used on a 3.2 or 3.6 |
Luke M |
Mar 29 2020, 06:50 AM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Thinking of getting a 3.2 or a 993 3.6. If using the factory 914-6 engine mount will I run into any clearance issues around the crank pulley area?
I know of a few other issues that I may encounter. For you 3.2 and 3.6 guys out there any words of wisdom before I jump into this? |
Steve |
Mar 30 2020, 04:33 PM
914 Guru Group: Members Posts: 5,589 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Maybe also check with http://www.tangerineracing.com/
They build quite a few of them and had one for sale awhile back |
RiqueMar |
Apr 6 2020, 09:32 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Should you change your mind, and decide to use the actual /6 mount, I went that route, and only had to slightly modify the cone.
http://www.914world.com/bbs2/index.php?sho...8955&st=680 Hope this helps and best of luck! |
Lo-Fi Version | Time is now: 18th May 2024 - 07:41 PM |
