Factory 914-6 engine mount clearance issue?, When used on a 3.2 or 3.6 |
Luke M |
Mar 29 2020, 06:50 AM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Thinking of getting a 3.2 or a 993 3.6. If using the factory 914-6 engine mount will I run into any clearance issues around the crank pulley area?
I know of a few other issues that I may encounter. For you 3.2 and 3.6 guys out there any words of wisdom before I jump into this? |
John |
Jun 8 2020, 03:09 PM
The 3.2 stock A/C pulley is easily cut off. On one conversion that I did, I used the 914-6 mount. On the others, I used modified 911 mounts with much shorter arms. Been doing it that way ever since. Of course, my front engine tin is a bit different than the stock 914-6 piece to accommodate the modified 911 engine mount.
I seem to recall that some of the later air cooled 911 engine cases are slightly different where the 914-6 mount and the 911 engine mounts bolt on. I think they added a threaded hole at some point and early mounts can be used if a stud is installed in the correct hole. The later mounts used the other threaded hole. (It's been a while since I've converted one, so perhaps I'm dreaming this up.) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:59 AM |
