Factory 914-6 engine mount clearance issue?, When used on a 3.2 or 3.6 |
larryM |
Apr 6 2020, 10:06 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
i did 3.2 with my oem -6 mount - no problems - you can't use a 3.2 AC dual pulley - must use single non-AC pulley (i had 2 3.2's - one was AC the other non-AC, so i just used the non-AC pulley - iirc any older 911 single pulley should also work)
(p.s. thanks for buying the Bott kit!) p. p.s. - for all: i have an oem -6 mount FS |
Luke M |
Apr 7 2020, 07:01 AM
Senior Member Group: Members Posts: 1,370 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Thanks for the input guys. The 3.6 did not work out so I went with a 3.2 engine instead.
I have a single belt pulley from a 3.2 here. Once the 3.2 get to me I'll mess around with the mount. I believe it should work just fine. Thanks Larry for selling me the Bott kit. (IMG:style_emoticons/default/beerchug.gif) |
Lg914 |
Jun 8 2020, 06:12 AM
Member Group: Members Posts: 53 Joined: 4-July 19 From: Lake Geneva Member No.: 23,275 Region Association: None |
mb911 |
Jun 8 2020, 06:55 AM
914 Guru Group: Members Posts: 6,819 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Sorry naroscape and pms.. The naroescape And Patrick motorsprts mounts are different In that they install the engine At different hights. Patrick motorsport Mount puts the engine about an inch higher than the naroescape one. That is good to know.. Stock oil line may fit then.. |
John |
Jun 8 2020, 03:09 PM
The 3.2 stock A/C pulley is easily cut off. On one conversion that I did, I used the 914-6 mount. On the others, I used modified 911 mounts with much shorter arms. Been doing it that way ever since. Of course, my front engine tin is a bit different than the stock 914-6 piece to accommodate the modified 911 engine mount.
I seem to recall that some of the later air cooled 911 engine cases are slightly different where the 914-6 mount and the 911 engine mounts bolt on. I think they added a threaded hole at some point and early mounts can be used if a stud is installed in the correct hole. The later mounts used the other threaded hole. (It's been a while since I've converted one, so perhaps I'm dreaming this up.) |
Lo-Fi Version | Time is now: 2nd May 2024 - 05:23 PM |
