Its about to go off topic .sprinter van owners chime in, How do you price a used sprinter van |
thelogo |
Mar 29 2020, 11:33 AM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
This is not for camping or shelter purpose
But im trying to build a mobile dog grooming salon Ive ruled out new and extremly expensive sprinters So that leave 1st and 2nd gen Here is one i made a offer on https://orangecounty.craigslist.org/cto/d/o...7094720538.html Are these going to be a maintence nightmare Or a strong work vehicle Poease advise (IMG:style_emoticons/default/wub.gif) and feel free to be long winded |
914forme |
Apr 1 2020, 06:52 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
it is missing at least one digit on the ODO reading.
The V6 of that age has a couple of issues. Oil cooler seals leak, oil cooler is in the V of the engine and you have to remove the entire intake, and fuel system ha to be puled to get to it. For two seals, and problem solved. Fuel injector seals will blow out, and produce a leak, which creates this nice black carbon structure, which is a pain to clean up. Seat needs to be cleaned, and then the copper O needs replaced. Oil and engine blow by is sucked out of the valve cover into an area right infront of the turbo. That seal leaks, and it fills the turbo, and Intercooler with oil over a long period of time. Seal at the turbo inlet also leaks. And should be replaced, easy to do when you do the filter change. Maintenance Oil changes cost me about $180 in parts to do it right 10 quarts of oil. Trans oil changes where also about $280, every 40K Fuel filters every 20K Air filters needed to be checked at oil changes, mine had an affinity to suck all the small insects to large insects off the interstate. And the wold need replace 9 time out of 10. As the pressure built do to restrictive filters the oil draw off the vent system would increase. Oh it burned 2 Quarts of oil over the 10,000 mile interval, majority of it was from the breather system. I had a Mann Hummel recovery unit on it, I would get about 1.5 quarts out of the system. Positives, engine ran great, I had a tune done on it, and it would get 27 MPG, never noticed anything I had behind it. I would still be driving it, if I did not find a deal on two BMWs. |
thelogo |
Apr 1 2020, 08:15 PM
it is missing at least one digit on the ODO reading. The V6 of that age has a couple of issues. Oil cooler seals leak, oil cooler is in the V of the engine and you have to remove the entire intake, and fuel system ha to be puled to get to it. For two seals, and problem solved. Fuel injector seals will blow out, and produce a leak, which creates this nice black carbon structure, which is a pain to clean up. Seat needs to be cleaned, and then the copper O needs replaced. Oil and engine blow by is sucked out of the valve cover into an area right infront of the turbo. That seal leaks, and it fills the turbo, and Intercooler with oil over a long period of time. Seal at the turbo inlet also leaks. And should be replaced, easy to do when you do the filter change. Maintenance Oil changes cost me about $180 in parts to do it right 10 quarts of oil. Trans oil changes where also about $280, every 40K Fuel filters every 20K Air filters needed to be checked at oil changes, mine had an affinity to suck all the small insects to large insects off the interstate. And the wold need replace 9 time out of 10. As the pressure built do to restrictive filters the oil draw off the vent system would increase. Oh it burned 2 Quarts of oil over the 10,000 mile interval, majority of it was from the breather system. I had a Mann Hummel recovery unit on it, I would get about 1.5 quarts out of the system. Positives, engine ran great, I had a tune done on it, and it would get 27 MPG, never noticed anything I had behind it. I would still be driving it, if I did not find a deal on two BMWs. Yes it was in sad shape the odometer had been switched At least the guy was honest about that when i asked (IMG:style_emoticons/default/bye1.gif) Rear main was leaking . cel light was on . A diaster But im considering staying far away from these for reasons stated in this post $$$$$$$ bleed |
Lo-Fi Version | Time is now: 11th May 2024 - 09:57 AM |
