FS Used Koni and Sachs- BOGE Rear Shock assemblies |
bdstone914 |
Mar 30 2020, 09:26 AM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have one set of Sachs- BOGE rear shocks. Everything but the springs are included. Upper perches are powder coated. Other parts were cleaned.
Price $125 for the pair shipped. Also one set of adjustable Special D Koni oil filled rear shocks. Lower perched zinc plated, upper perches are powder coated. All other assembly hardware except springs are included. Price $150 for the pair shipped. I have used stock springs for $20 a pair plus shipping at cost. I can measure the unsprung length and ensure they are in spec. I also have four pair of rear tested Sachs-BOGE shocks only. No lower perches. You need to reuse you stock lower perches. The lower perches are unique to Sachs-BOGE shocks. All of these Sachs-BOGE were tested by Eibach and showed consistant resistance on compression and rebound. Pictures to be added later. Price $75 for the pair shipped. And for those eagle eyed viewers, yes i know the some of the parts were installed upsidedown. (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) |
Tdskip |
May 3 2020, 08:45 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
@bdstone914 - looking for one good used rear Koni red to match one that I have. Let’s try to connect and maybe I can run by and also pick up the KYB strut insert.
Thanks! |
bdstone914 |
May 3 2020, 10:05 AM
@Tdskip
' date='May 3 2020, 07:45 AM' post='2811215'] @bdstone914 - looking for one good used rear Koni red to match one that I have. Let’s try to connect and maybe I can run by and also pick up the KYB strut insert. Thanks! [/quote] Only found one KYB sturt nut so far. I saw a pair recently. Call me and we can work out a time. Bruce |
rfinegan |
May 3 2020, 10:56 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Have any Koni fronts?
Lo-Fi Version | Time is now: 28th April 2024 - 07:17 PM |
