Advice needed - Spark plugs, leads and carbs, 914-6 |
Dobbsy |
Mar 31 2020, 01:58 PM
Newbie Group: Members Posts: 49 Joined: 22-May 14 From: West Midlands Member No.: 17,382 Region Association: England |
Hello,
I have a few questions that I need help on. I bought my 6 back in August and it was running rough. I am now replacing the fuel lines with stainless steel and new rubber hoses. I will also be changing the plugs, leads, dizzy cap and rotor arm so everything is new. The PO has also put a fuel regulator on which I am not sure if that should be there. Is seems a good idea so I plan on keeping it but adding a gauge to see the pressure. Is there a standard for fuel pressure gauges? Any recommendations. I have not removed the fuel pump yet how do I identify it is correct, do the ones for carbs look the same as injection. I have been caught out by this before. I have bought an ultrasonic cleaner for when I rebuild the carbs, does anyone know of any good sources / tutorials for this. I am planning on getting Magnecor leads but the sales assistant asked me to check the coil lead length, the one in the car is 16.5" and the one in their catalogue lists it as 9.5”. as the one in the car looks longer than it should do, I believe the correct length should be 9.5”. Is this correct? Spark plugs, what do people recommend, either sticking with the standard rating plug or selecting a colder rating, the car will only be used on the road. When I took the fuel tank out and removed the fittings from the bottom there was not a gauze filter, should the be one on a 1970 car. What is the method of choice for cleaning the tank out, there is a bit of light rust inside. |
porschetub |
Mar 31 2020, 02:41 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
OK hopefully my answers are in the right order;
A fuel pressure regulator is needed with most pumps IMO ,without a gauge you have no way of knowing,I run just over 3 psi with Zeniths and I believe Webers are similar. You need to find out what pump you have first,most common aftermarket is the CB Performance/Carter low pressure pump which is rated @ 3.5psi,I have this unit and found it delivered more but I had a holley regulator and adjusted it down as I had minor fuel overflow in the throats...problem solved. Depends on what carbs you have,there is a UK site covering Zenith rebuild and plenty of other info on Webers (more common) on US sites. Buy the Clewett Engineering lead set part # 9192-28,plug and play and very nicely made,can be purchased direct from Clewett or Pelican stock them,great product. Plugs ? buy standard heat range Bosch or NGK ,some say the NGK are better ...don't know but have a set I might fit soon to see. Best to run gauze strainer of the tank but if you can't get one straight off you will be ok with one inline hose filter till you buy the tank one,I think 914rubber sell a kit. Good luck (IMG:style_emoticons/default/beer.gif) . |
Lo-Fi Version | Time is now: 24th May 2024 - 04:40 PM |
