Led Bulbs for Fog Lights |
PCH |
Apr 1 2020, 01:06 PM
Member Group: Members Posts: 140 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California |
I know this topic has come up before without a specific LED bulb being mentioned. Are there any plug and play LED bulbs for fog lights? I have searched the internet and not found any. Just making sure I didn't miss anything.
Thank you, Peter |
dangrouche |
Apr 3 2020, 11:18 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
I scoured the market for single contact bulb, and they do not exist. I dreamed up an inexpensive mod since I have a pair of OEM bulbs looking for some modifications so I desoldered them (OEM BA20S). I ordered a set of BA20D bulbs from eBay and will disassemble those to fit the OEM fog bulb socket. More to follow whenever I get the eBay bulbs. (https://www.ebay.com/itm/1x-H6-BA20D-DC-9V-85V-12W-White-COB-LED-Motorcycle-Hi-Lo-Beam-Headlight-Bulb-Hot/114109146891?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649)
Spoke |
Apr 3 2020, 04:45 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I scoured the market for single contact bulb, and they do not exist. I dreamed up an inexpensive mod since I have a pair of OEM bulbs looking for some modifications so I desoldered them (OEM BA20S). I ordered a set of BA20D bulbs from eBay and will disassemble those to fit the OEM fog bulb socket. More to follow whenever I get the eBay bulbs. (https://www.ebay.com/itm/1x-H6-BA20D-DC-9V-85V-12W-White-COB-LED-Motorcycle-Hi-Lo-Beam-Headlight-Bulb-Hot/114109146891?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649) It would be desirable to use the LED bulb as is if possible. Electrically you may be able to power both low and high settings by bridging both buttons together with solder or solder and a wire the powering both at the same time. If you did that with the LEDs I make then they would just light up brightly with no issues. The only issue you might have is if the tabs on the side are at different heights. They do that with dual button bulbs so they are not installed backwards. That LED bulb looks like it might be bonded to the base as they probably use the base metal as part of the heatsink. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:50 PM |
