Warning- #043 MPS now list @$1,652.50, Get one while you can (used or rebuilt) |
Bleyseng |
Jul 6 2005, 07:24 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Woohoo, a euro MPS!
We are planning to come to the Netherlands in late Sept, soo will the 914/6 be running??? We should hook up then. Wanna go to Spain? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
JeffBowlsby |
Jul 7 2005, 07:10 AM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Glad we could help out William. Actually the mps only had a subtle leak, it would have worked for a long time, but it was not right and I am glad you were able to replace it. I hope the replacement is a good one and it should last a loooong time. The orioginals seem to last 20-30 years.... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I suspect the leak was from dry case seals...easy enough to repair. All of the MPS values I have are available to anyone...they are direct from the D-Jet Master....Brad Anders website. I posted the link recently to the pulse width values chart for anyone tuning a stock FI using stock fuel pressure and injectors. |
Jeroen |
Jul 7 2005, 07:48 AM
are they any different???? (I wouldn't know a 4 banger part if it bit me in the ass (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif))
Won't be running, but I should have it back from the bodyshop some time in august (keeping fingers x-ed) and I should have some time off in august to work on it...
Definately!
Tapas, paella (IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif) |
rhodyguy |
Jul 7 2005, 08:02 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i need to test the one that came off the 73'.
k |
Bleyseng |
Jul 7 2005, 08:12 AM
Kevin, Just pump it to 15hg with a vacuum pump and let it sit for 5 minutes to see if it bleeds down.
Has the epoxy been removed and the machined plug drilled? If so it can be reset. Yes Jeroen, Paella and tapas!! I'll let you know when and where as maybe you can sneak out for a little vacation with us. The numbers I have found for the 037 MPS are: .74 15hg 1.12 4hg 1.52 0hg which means it is set up to run richer at idle and way richer at WOT (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
rhodyguy |
Jul 7 2005, 08:17 AM
epoxy plug intact. if you're going to walkers this month can you bring your pump with you for a quick field check? if it holds vaccum, are there resistance values that need to be met to insure it's a servicable unit? pm sent in 2 minutes.
k |
MarkG |
Jul 7 2005, 10:09 AM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
This ain't good news...$1600!.
I have 2 rebuilt 043 MPS's ....one as a spare. I have been having idle problems even after $400 worth of new injectors installed Saturday. Just for the heck of it I swapped MPS's and all idle/power issues went away. That means a rebuilt MPS has a life span of 250 miles! @$200+ per rebuild that adds up to several thousand dollars a year of normal driving. Time to convert to carbs.....I already have over $2K invested on NEW D-Jet componants....talk about throwing good money after bad! Maybe I SHOULD have kept the 308......(except the 914 is more fun to drive, albeit a little short on power compaired to the F car). |
airsix |
Jul 7 2005, 10:36 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Converting to carbs? (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) Would you amputate your arm because of a hangnail? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (jk) You could convert to megasquirt EFI for a couple hundred bucks (probably half the cost of carbs). That would be the cheapest EFI option and there are a dozen others. In this day and age there is no reason to put carbs on anything but chainsaws and weedwackers. EFI good. Carbs bad. -Ben M. |
Joe Bob |
Jul 7 2005, 10:44 AM
Think of all the money you saved on gold chains and powder blue leisure suits.... |
TJB/914 |
Jul 7 2005, 11:58 AM
Mid-Engn. Group: Members Posts: 4,333 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
MarkG & Mr. Z
Your comments owning a 308 made me chuckle. My brother had one & still has his gold chains & blue L-suit. I blame our mom for his downfall. To all others. This MPS price situtation is a "Wake Up Call" We need alternate solutions. Don't think about going carbs. We just need to find an inexpensive (cheaper) fix. Untill that happens start looking for spares to keep our 914's running. Tom BTW Keep supporting our 914 vendor's. We need them. |
Brando |
Jul 7 2005, 12:01 PM
Come out of the dark ages... come to the L-Jet side (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Engman |
Jul 7 2005, 12:34 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Someone (hint, hint) should look at using a more modern pressure sensor and adapt it to a plug and play unit. Could be a good mod.
Look here M |
phantom914 |
Jul 7 2005, 12:38 PM
non-914-owner non-club member Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 |
It's not so simple. Modern sensors have a voltage output. The MPS has a varying inductance that is part of a tank circuit that determines pulse width. For the trouble, might as well change to a new EFI system. Andrew |
Bleyseng |
Jul 7 2005, 01:08 PM
Those sensors work with pressure , not vacuum!
Kevin, I will be gone outta town that weekend (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) When is that BBQ gonna happen that you and DaveH promised??? timing is gud for this summer...lots of sun, no rain, hint hint. |
RustyWa |
Jul 7 2005, 02:04 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
Kevin, I plan on going to the swap meet. I can bring my vacuum pump along if you need one. Probably a good idea to just bring it so I can test any that might be for sale. |
MarkG |
Jul 7 2005, 09:02 PM
Well, I just vacuum tested the Bret 043 MPS I had rebuilt via PP 250 miles ago (ironic = $1.00 per mile of service).....would not hold vacuum for more than 20 seconds......
The AA rebuilt MPS is doing fine so far @ 45 miles use. |
Bruce Allert |
Jul 7 2005, 11:25 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
BAR-B-QUE??? (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) Someone mention BAR-B-QUE??? MMMMMMmmmmmmmm... give me a couple weeks notice & I'll make the journey for that! Oh, and what's a good used MPS worth these days? I have one from my 1.7 that I think is fine but haven't done the vacuum test Geoff mentioned. .........b |
Bleyseng |
Jul 7 2005, 11:35 PM
$75
Come on, Kevin. What about that BBQ???? |
dmenche914 |
Jul 8 2005, 12:27 AM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Funny, i have run my old MPS for ten years with no failure.
What could be wrong? there are two coils, they could short, or open electircally. the container could develop a vacuum leak, the diaphram can fail. the spring could change tension Dirt could get inside interfering with the movement what would could cause each of these failures? electric problems on the coils could be caused by an over voltage that melts the insulation or burns out the coil, the container could get a leak form vibration that owuld cause the body to rub on the car, wearing a hole. the diaphram could fatigue, but mine has lasted a decade at least it might even be the original one, I do not know. the diaphram might corrode, but what from, storage conditions in the stock room? Did crud get in teh vacuum hose port and move around inside until it jammed the motion? Spring tensin loss, high temperature could do that, but that temp would also melt the plactic parts, so that not likely. this is a mystry alright. |
DNHunt |
Jul 8 2005, 07:48 AM
Geoff
You already missed the Barbie. it was in May at Kevin's when all of the rhodys were blooming. he yard was spectacular. My MPS is the size of a quarter and costs less than 20 bucks. It does respond to vacuum. 1 bar is 100 Kpa. The sensor will repond from 0 to 250 Kpa so that's 1 bar vacuum to 1.5 bar of boost (It would be fun to play with that side of the MPS). On decel my engine will pull as much as 84 Kpa of vacuum. Idle is around 67 Kpa of vacuum and WOT is about 1-3 Kpa of vacuum. Dave |
Lo-Fi Version | Time is now: 1st June 2024 - 01:51 PM |
