Rebuilding intake of a 2.0 D-Jet, PCV or no PCV? |
sofi2t81 |
Apr 7 2020, 06:40 AM
Member Group: Members Posts: 85 Joined: 6-December 10 From: Meine, Germany Member No.: 12,458 Region Association: Germany |
Hi there,
After having problems with the emission test all the years here in Germany (high CO) I started to fix the D-Jet with rebuilding the intake system to sort out the leaks. While disassembling the thing I found some creative solutions from the PO. (IMG:style_emoticons/default/barf.gif) The seal from the throttle to the plenum missed a piece but was „sealed“ with some gunk („Bärenscheisse“ you may have the right english word too). Seal between runners to cylinder head had the same black paste in a crack. Thermo switch wire was broken and drilled together with a little tape under the plenum. I replaced most of the Vacuum hoses some years ago. Sadly not the crankcase vent. The PCV valve was connected to the plenum but there was u T connection to the charcoal canister wich wasn’t easy to see. The PO then blocked the T side to the plenum with glue. So no crankcase vent... (IMG:style_emoticons/default/WTF.gif) Oil separator gasket was glued in as well And finally three screws of the crankcase split were loose...with one nut missing (IMG:style_emoticons/default/headbang.gif) And some minor things... What I did so far. I cleaned all the parts, removed all the gaskets, glue and rust. Painted everything. Now the question. Should I reconnect the PCV or not? The valve operates when I apply some vacuum. How is idle stability with the PCV? Thanks for help Stay save, stay home, stay healthy Peter |
sofi2t81 |
Apr 7 2020, 02:18 PM
Jupp, thats it. Exactly that.
Lo-Fi Version | Time is now: 17th May 2024 - 11:12 PM |
