FS Misc Parts for 914/912E/911, Excess Project parts, most new 50% off original OBO |
Bulldog9 |
Apr 7 2020, 03:33 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Using the downtime to clear out some of my leftover parts. All parts unless noted are new and never installed or run. Prices are + shipping. All prices are less than 50% off MSRP, but willing to deal, bundle and move these parts.
UPDATED TO REFLECT SOLD PARTS PM for pictures and details, or more information. 911/912E URO Rear glass weather strip - $25.00 911/912E Porsche Rear Engine Compartment Seal - $25.00 912E Exhaust Gaskets (OEM Porsche #923 11 151 01+C201) - $20.00 911/912E Transmission Mounts (2) - $25.00 *test fit installed, never run. I went with sport mounts instead 911 Front door harness and door wiring dust caps - $10.00 *Used, taken from door of an 86 Carrera 914 Alternator Cooling Plate (2) - $10.00 *Used, good condition 3 POD Plastic 2" VDO Gage Holder - $5.00 2" 12V VDO Clock - $35.00 *test fit installed, ended up using original 911 Heat and volume (control) missing fan switch - $5.00 Used from salvage 911 Headliner Tension Wires 1-4 - $30.00 914 Reman Alternator New never installed - $75.00 SOLD CB Performance Cross Bar Throttle Linkage Pack - Includes Steel Hex Cross Bar - 20 5/8" - $50.00 SOLD 911/912E Front glass weather strip (OEM Made in Germany) - $50.00 SOLD 912E/914 CB Performance Air Filters/Bases with hardware - $25.00 *test fit installed, never run. I went with a pulley system instead. SOLD SCAT bell crank Throttle control linkage - $40.00 *test fit installed, never run. I went with a pulley system instead. SOLD 912E/914 Original Customs Throttle Cable Bracket - $10.00 SOLD 912 E Bursch Exhaust (C 1990) New never installed - $225.00 SOLD 914 Sachs Throwout bearing and bushing caps - $50.00 SOLD NOS Bosch distributor cap and rotor kit (extra cap/condenser) -$10.00 **Fits stock distributor. Truly NOS, is in plastic display package. Will also throw in an extra cap and condenser. I am running the Pertronix plug and play (large distributor) SOLD Set of Lemforder Tie Rod Ends 10710 03 009 - $25.00 **NEW IN BOX. This is for the stock rack and tie rods. I went with the turbo rack which uses different tie rods. SOLD 912E/914 Bosch Fuel Pressure Regulator (Porsche box) - $70.00 SOLD 911/912E Clutch Pedal Return Spring - $5.00 SOLD |
ndfrigi |
Apr 9 2020, 09:26 AM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
pm sent for 3 items
Lo-Fi Version | Time is now: 17th May 2024 - 03:24 PM |
