What’s this noise..., Rear left wheel when turning left? |
MikeInMunich |
Apr 11 2020, 12:46 PM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Pretty sure it’s when I turn to the left...clunk clunk clunk clunk clunk...the faster I’m going, the faster the clunking, from the rear left wheel. I changed my CV joints last year.
Thanks for your insight. M.i.M. (IMG:style_emoticons/default/beerchug.gif) |
burton73 |
Apr 11 2020, 01:37 PM
burton73 Group: Members Posts: 3,531 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Did you put in new ones of a good quality? Are you sure they have not come lose?
Years ago I had a noise and it was a loss CV. back in 1978 with my 74 car Bob B |
Apr 11 2020, 01:58 PM
Resident German Group: Admin Posts: 41,656 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Do a search here, there's been a lot of discussions about the quality (or lack thereof) of some of the recently available new CVs.
(IMG:style_emoticons/default/dry.gif) |
Mark Henry |
Apr 11 2020, 02:32 PM
Check your outboard CV's, one's loose. Likely in with only one or two bolts.
Like @PatrickB at last years 50th at Mosport. (IMG:style_emoticons/default/dry.gif) |
MikeInMunich |
Apr 11 2020, 03:49 PM
Check your outboard CV's, one's loose. Likely in with only one or two bolts. Like @PatrickB at last years 50th at Mosport. (IMG:style_emoticons/default/dry.gif) Should have mentioned...I only changed the inner bearings. Guess the outer could be wasted, too, as opposed to just loose. (IMG:style_emoticons/default/dry.gif) |
Retroracer |
Apr 11 2020, 05:35 PM
Senior Member Group: Members Posts: 613 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
What Mark_Henry said, check the security of the CV bolts. 914Rubber sell some bolts predrilled for safety wire, which is extra insurance if any did work loose.
The noise you describe sounds like CVs, not wheel bearings - I went through this last summer, replacement CV joints fixed it. Mine were sufficiently shagged that getting under the car you could feel the rotational play by rocking the shafts by hand.... - Tony |
djway |
Apr 11 2020, 09:02 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
I had the same exact noise when I first got the 914 I now have.
Outboard CV bolts were missing and ultra loose. |
Krieger |
Apr 11 2020, 09:16 PM
Advanced Member Group: Members Posts: 4,721 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
The outside bearing move up and down farther and wear faster than the inners.
MikeInMunich |
Apr 13 2020, 04:22 AM
What Mark_Henry said, check the security of the CV bolts. 914Rubber sell some bolts predrilled for safety wire, which is extra insurance if any did work loose. The noise you describe sounds like CVs, not wheel bearings - I went through this last summer, replacement CV joints fixed it. Mine were sufficiently shagged that getting under the car you could feel the rotational play by rocking the shafts by hand.... - Tony Thanks Tony. I was under there yesterday. Bolts aren’t loose. It’s eithe Ruhe CV joint or the bearing. Will be putting it up on a lift to have a better look tomorrow. |
PatrickB |
May 9 2021, 04:32 AM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
Check your outboard CV's, one's loose. Likely in with only one or two bolts. Like @PatrickB at last years 50th at Mosport. (IMG:style_emoticons/default/dry.gif) Live and learn! (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 25th May 2024 - 01:58 AM |
