Aualexa1 |
Newbie ![]() Group: Members Posts: 45 Joined: 17-June 17 From: South Jersey Member No.: 21,189 Region Association: MidAtlantic Region ![]() |
I'd like to replace the seals on the chassis for the doors and the targa top on my '73. The door seals seem like they'd be pretty easy to do, but I've read the targa seal is more difficult. Any advice? Even better...anyone have video of the replacement?
TIA Alex |
SA-914 |
Member ![]() ![]() Group: Members Posts: 129 Joined: 30-June 14 From: San Antonio,tx Member No.: 17,566 Region Association: Southwest Region ![]() |
I did the two targa seals above the doors windows. You have to use a flat tip like a 3/8" wide screwdriver to push in each section. You cannot slide this stuff in the channel. I did use some glycerin to help it snap in, 1/4" at time. Drive side took more than an hour. I did the other in about 20 minutes. I lined up the diagonal cut piece and left the other long the started cutting it back as I test fitted until I had a tight fit.
I'd like to replace the seals on the chassis for the doors and the targa top on my '73. The door seals seem like they'd be pretty easy to do, but I've read the targa seal is more difficult. Any advice? Even better...anyone have video of the replacement? TIA Alex |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
We've done up a video but haven't edited it yet.
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,185 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
very easy the front windshield seal has to be run down the gutters first and then bumped on to the lateral strip and the top side seals "stuck" into the inside of the gutter and then pinched into the outside of the gutter. Silicone grease is your friend, and make sure you bunch the seals in for a tight fit without cutting them
Lo-Fi Version | Time is now: 6th July 2025 - 05:16 AM |
