CV joint plates |
CV joint plates |
doug_b_928 |
Apr 18 2020, 04:56 PM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I cleaned the grease off of my cv joint plates today, which raised two questions:
1. Is this wear a concern for re-use? 2. What was the original finish, plated with black chromate or painted black? |
pete000 |
Apr 18 2020, 05:13 PM
Cad plated, That wear should not present a problem, have them re plated and reuse...IMHO
Superhawk996 |
Apr 18 2020, 05:16 PM
914 Guru Group: Members Posts: 5,830 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
That gouge won't hurt a thing. Just deburr the back side if it doesn't sit flat. Best practice is to use fresh schnorr washers though. You'll be tempted to resuse the old ones. I've reused them back in the days when I was broke and before I knew better. If you can swing it - use fresh ones they will be less likely to loosen. Someone else will chime in on the original finish. |
doug_b_928 |
Apr 18 2020, 05:41 PM
Thanks, guys. Yep, I'll use new schnorr washers for sure. Just need to know the finish on the plating now (yellow or black).
davep |
Apr 18 2020, 06:58 PM
I don't recall any finish on them. I think it was just plain steel with an oil dip.
Mikey914 |
Apr 18 2020, 07:27 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I don't recall them being plated, but most are pretty dirty.
Have the schorr washers in stock if you need some. Also have the drilled CV bolts too if you decide to safety wire in place |
914Sixer |
Apr 18 2020, 08:00 PM
914 Guru Group: Members Posts: 8,883 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Original ones are black oxide. VW part
doug_b_928 |
Apr 18 2020, 09:23 PM
Perfect. Thanks very much guys.
Lo-Fi Version | Time is now: 19th May 2024 - 12:21 PM |
