doug_b_928
Apr 18 2020, 04:56 PM
I cleaned the grease off of my cv joint plates today, which raised two questions:
1. Is this wear a concern for re-use?
Click to view attachment2. What was the original finish, plated with black chromate or painted black?
pete000
Apr 18 2020, 05:13 PM
Cad plated, That wear should not present a problem, have them re plated and reuse...IMHO
Superhawk996
Apr 18 2020, 05:16 PM
That gouge won't hurt a thing. Just deburr the back side if it doesn't sit flat.
Best practice is to use fresh schnorr washers though. You'll be tempted to resuse the old ones. I've reused them back in the days when I was broke and before I knew better. If you can swing it - use fresh ones they will be less likely to loosen.
Someone else will chime in on the original finish.
doug_b_928
Apr 18 2020, 05:41 PM
Thanks, guys. Yep, I'll use new schnorr washers for sure. Just need to know the finish on the plating now (yellow or black).
davep
Apr 18 2020, 06:58 PM
I don't recall any finish on them. I think it was just plain steel with an oil dip.
Mikey914
Apr 18 2020, 07:27 PM
I don't recall them being plated, but most are pretty dirty.
Have the schorr washers in stock if you need some. Also have the drilled CV bolts too if you decide to safety wire in place
914Sixer
Apr 18 2020, 08:00 PM
Original ones are black oxide. VW part
doug_b_928
Apr 18 2020, 09:23 PM
Perfect. Thanks very much guys.
