CHT Sensor, Stock L-Jet Sensor vs Spark Plug Sensor wiring |
Rikyrat |
Apr 20 2020, 09:43 AM
Member Group: Members Posts: 58 Joined: 30-January 19 From: Phoenix Member No.: 22,844 Region Association: None |
Hi All:
Have a question, I am in the midst of final wiring on my megasquirt injection system. Since it uses it own CHT sensor, I am thinking about using the Stock CHT sensor to monitor temps. I Currently have a ring sensor on the number 3 cylinder, but was considering removing it. The problem I have is that the ring sensor has 2 wires going to a connector and the stock only has one. I believe that the stock sensor is grounded to the block itself. Is there any way to adapt the stock sensor to use it. Should I connect one of the pins on the ring sensor connector to ground, or will that totally screw things up. Thanks for any assistance |
Lo-Fi Version | Time is now: 19th May 2024 - 08:34 AM |
