Hi All:
Have a question, I am in the midst of final wiring on my megasquirt injection system.
Since it uses it own CHT sensor, I am thinking about using the Stock CHT sensor to monitor temps.
I Currently have a ring sensor on the number 3 cylinder, but was considering removing it. The problem I have is that the ring sensor has 2 wires going to a connector and the stock only has one. I believe that the stock sensor is grounded to the block itself.
Is there any way to adapt the stock sensor to use it. Should I connect one of the pins on the ring sensor connector to ground, or will that totally screw things up.
Thanks for any assistance
