How can I make this fit?, Targa bar trim meets sail panel strip |
jack20 |
Apr 22 2020, 11:23 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
I’m getting close. I’ll post pictures and describe the process when finished.
Jack |
BPic |
Apr 23 2020, 07:57 AM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
I'm not in front of your car but it looks like you could move the wide sail panel trim piece to the outside. You might have to shave a bit off the little square retaining clamp that fastens the end of the trim to the body. I just went through this recently on my car. You should have a bit of adjustment in the special square retaining clamp to be able to move it outboard or inboard a little. If you don't have enough, just slot the hole for the clamp stud a little with a file and paint the raw edges. Getting to the clamp nut under the fender is a PITA, but you should be able to line that targa trim piece up better than what you have. (IMG:style_emoticons/default/agree.gif) I just did the same thing. |
dr914@autoatlanta.com |
Apr 23 2020, 09:07 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the only way it is going to fit is to bend the rear roll bar chrome
This is what I’m trying to overcome. I realize there are a lots of reasons why it may not or won’t fit, including poor design, stamping variations, etc however this is a very original, un-messed with car and I just bought new Porsche trim for it and good enough isn’t unless I’ve exhausted all options. I’ve seen it done well and hoping someone who knows how to maximize the tolerances will share how they’ve done it. Compare this picture to the red car. It appears that I could simply move the covering piece over but that’s due to the angle of the photo. It’s centered. |
jack20 |
Apr 23 2020, 06:22 PM
Got it finished today. Pretty happy with the outcome.
To start I bought new top plates and sail panel back trim from Porsche. A few dealers have a discount parts program. Mine doesn’t but they price matched and I avoided shipping cost. The top plates had to be trimmed at the rear to fit flush with the top of the bar and line up with the rear sail panel trim. The sail panel trim required filing on the inboard back side that fits the inside of the sail panel. Filing allowed the trim to slide outward enough to cover the tab on the thin strip at the bottom of the sail panel. The mounting plate needed filing on the engine sides of each. I used a long 1/4” drive extension and 8mm socket to attach the nut and washer under the fender. I stuck the nut and washer together with contact cement and raised them to the bolt. Done. Thanks for the suggestions. |
Superhawk996 |
Apr 23 2020, 06:24 PM
914 Guru Group: Members Posts: 5,876 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/cheer.gif) Welll done. (IMG:style_emoticons/default/smash.gif)
Apr 23 2020, 06:48 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:43 AM |
