How much Noise should the TOP make?, Rub'n, shift'n and mov'n all of the " 'ns " |
ctc911ctc |
Apr 24 2020, 07:02 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All Teeners,
Focusing on the things that bug me. When driving down a bumpy road (which is every road in the Boston area) the top makes a great deal of noise on top of the sail. I have all new 914Rubber front and back and all over the car BTW. I have tightened the latches as tight as I dare. Both doors are tight and fit well. I also have added Brad Meyers tub stiffness: https://914ltd.com/product/porsche-914-chas...-repair-panels/ Perhaps a few thoughts as to how to test for body flex longitudinal? Might this be the culprit, twisting??? Thank you, CTC911CTC |
Mark Henry |
Apr 24 2020, 07:33 AM
That's just the gerbils in the engine complaining. (IMG:style_emoticons/default/biggrin.gif)
Perhaps a few thoughts as to how to test for body flex longitudinal? Might this be the culprit, twisting??? Thank you, CTC911CTC Some guys use a silicone spray to tone down the squeaks. Put a jack under the rear lift donut or on the long right under the rear of the door and watch the gap as you lift. I have my '74 which is "rust free" and never been restored, if I roll it out of my shop (over a bump) and place my palm over the windshield hoop and top gap I can feel the top squirreling around. My wife's '72 is a restored rust bucket with new clam shells and an inner long kit. If I do the same as above the gap doesn't move a bit. Inspecting my '74 I can see some hairline cracks at the e-brake handle area. Someday I plan to put an inner long kit in my teen, but even with the stiffest chassis you will still have squeaks. |
Superhawk996 |
Apr 24 2020, 07:58 AM
914 Guru Group: Members Posts: 5,830 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Too high of expectation
These are not modern cars. As previously stated by Mark, Silicone Spray and Armor All can help. Krytox is what the auto industry uses on certain problem areas like windshield surrond trim and what will be most effective of the targa rubber to body interfaces. There are all kinds of grades of Krytox ranging from https://www.ebay.com/i/184197562621?chn=ps&...BiABEgIXVfD_BwE to more OEM versions that cost up to $100 for 2 oz but it lasts and it works and 2oz will do hundreds of cars. If you really want to eliminate all squeeks and rattles, you're going to have to buy either NVH felt flocking like this https://www.amazon.com/Anti-Squeak-Rattle-A...d/dp/B012D23HDE or anti-squeek polyethylene tape https://www.grainger.com/product/15D284?gcl...33;437026409190! Use at interfaces between trim parts that can move relative to each other. If you've ever worked on a modern Japanese or German vehicle you'll have an idea of where this stuff goes. |
ctc911ctc |
Apr 24 2020, 08:41 AM
Superhawk (Studebaker guy?) thank you!
Seems that both you AND I have too high expectations. How else would you know about all of these great remedies? I will try them this weekend, Thank you! Too high of expectation These are not modern cars. As previously stated by Mark, Silicone Spray and Armor All can help. Krytox is what the auto industry uses on certain problem areas like windshield surrond trim and what will be most effective of the targa rubber to body interfaces. There are all kinds of grades of Krytox ranging from https://www.ebay.com/i/184197562621?chn=ps&...BiABEgIXVfD_BwE to more OEM versions that cost up to $100 for 2 oz but it lasts and it works and 2oz will do hundreds of cars. If you really want to eliminate all squeeks and rattles, you're going to have to buy either NVH felt flocking like this https://www.amazon.com/Anti-Squeak-Rattle-A...d/dp/B012D23HDE or anti-squeek polyethylene tape https://www.grainger.com/product/15D284?gcl...33;437026409190! Use at interfaces between trim parts that can move relative to each other. If you've ever worked on a modern Japanese or German vehicle you'll have an idea of where this stuff goes. |
VegasRacer |
Apr 24 2020, 08:48 AM
ELVIRA Group: Benefactors Posts: 8,509 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
I went with the low tech, non concours soultion.
Just wedge a matchbook in there. (IMG:style_emoticons/default/smilie_wirdgut.gif) |
rhodyguy |
Apr 24 2020, 08:49 AM
Try the one sided felt tape in the recesses on the targa bar where the rubber stand offs rest. With so many stores closed, try a Walgreens type and look in the sewing 'notions'.
jim_hoyland |
Apr 24 2020, 09:13 AM
Get that VIN ? Group: Members Posts: 9,302 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
? Possible 914 Rubber upgrade ? (IMG:style_emoticons/default/smile.gif)
Superhawk996 |
Apr 24 2020, 09:58 AM
Superhawk (Studebaker guy?) thank you! Seems that both you AND I have too high expectations. How else would you know about all of these great remedies? @ctc911ctc Nah, my expectations for 914's are pretty low. (IMG:style_emoticons/default/happy11.gif) But, my love of my 1st 914 and the time I spent working on it in my 20's is what motivated me to become an automotive engineer as a career. I've spent way too many years of my life working on things like NVH, water leaks, powertrain noises, etc., but it has been a fun ride for the past 25 years. (IMG:style_emoticons/default/biggrin.gif) We'll see how much longer I can go, but I supect the panicdemic is about to kill the industry along with many others that have already lost their jobs. (IMG:style_emoticons/default/sad.gif) |
porschetub |
Apr 24 2020, 04:32 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Jim 914rubber sell a basic rear roof seal and an improved version which has a fluffy coating on it (for want of a better word ?) Mark mentions it on the website,I see one of these for my car in the future,with the clamping of the latches and the movement of the roof and the car flexing they just wear out. I'am going to fit a set of Bruces rebuild rear latches to hopefully pull the top down a little more but in reality its a bandage for a broken leg,this seal needs to be in good condition or replaced. |
Chris914n6 |
Apr 24 2020, 05:11 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Likely the rear latch bumpers are dry & hard. Easy test is to undo the rear latches and listen.
jim_hoyland |
Apr 24 2020, 05:16 PM
Could those latch bumpers be replaced ?
bandjoey |
Apr 24 2020, 05:49 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I put a piece of very small rubber hose on the latch pin and it stopped the problem.
Mikey914 |
Apr 24 2020, 05:54 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Your noise is more than likely the rubber bumpers on the roof that the latch tightens down onto. With the fuzzey on the rear, it's the only other point of contact.
-Mark |
brcacti |
Apr 24 2020, 06:10 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Mine has many rattles and noises, wind sounds from windows, it's a good survivor, nice shape but it's OLD. If I were a mechanic I probably would try hunting down some of the noises but have not yet bothered with it.
Chris914n6 |
Apr 24 2020, 07:39 PM
Could those latch bumpers be replaced ? uro makes some but they don't specify early or late. URO Parts 91456303319 Targa Top Mounting Block, Rear Mounting BLock (IMG:http://www.914world.com/bbs2/uploads_offsite/images-na.ssl-images-amazon.com-431-1587778912.1.jpg) |
PanelBilly |
Apr 24 2020, 08:14 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Mine also squeaks too much. If I put a scrap of polishing towel between the roof and the top of the sail panel, sometimes its quiet, but then I have trouble unlatching the clamp on that side. I think its too tight and I need to press down on the roof to take the pressure off it. I have the new rubber seals on it. I was thinking maybe I need to shim the rubber seal in that area.
Lo-Fi Version | Time is now: 19th May 2024 - 11:19 AM |
