Moved the fuel pump to the front., Traded orridgenalty for more dependable |
rstover |
Apr 24 2020, 03:29 PM
Member Group: Members Posts: 136 Joined: 15-November 11 From: Kerrville, TX Member No.: 13,785 Region Association: Southwest Region |
I wanted to keep the car as original as possible but felt I would get more reliability by going with a 2 port and moving it to the front. I searched the 914 world first and found various opinions. Here is what I ended up with.
Bracket from a 75 or 76 914. This only required two 1/4 inch holes. Reducers from Tangerine racing. One U shaped and one strait. Some fuel hose and electrical wire. I not sure that I needed to but I ran the wire from the back original fuel pump connector both the positive and the ground. : The second picture I attempt to show the routing of the hose. Out of the supply nipple from tank it is looped around the front brace and goes into the strait reducer from large hose about 9.5 mm to 8 the small goes to the driver side brace then thru the master cylinder to the filter . From the pump I used the U shaped to go from the small back to the large. I had already put stainless lines in the tunnel. I want to thank the previous poster on this topic and Mark and Chris for their help. |
ndfrigi |
Apr 24 2020, 03:38 PM
Advanced Member Group: Members Posts: 2,931 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Thank you for sharing! Will be doing the same for my 74 project.
rstover |
Apr 24 2020, 03:59 PM
I forgot to mention that I needed to change the angle of the supply nipple on the tank.
The supply nipple is rotated almost parallel to the tank but about 5 degrees from parallel One advantage or two is that it is easier to remove tank and reinstall. The tank can be drained by undoing the strait reducer and you can attach the supply hose to the tank before you put it in and then attach to the reducer. |
Montreal914 |
Apr 24 2020, 08:40 PM
Senior Member Group: Members Posts: 1,568 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Thank you sharing. (IMG:style_emoticons/default/beerchug.gif)
I am about to do this while on a Microsquirt conversion project. I will use a 75-76 fuel pump access panel and duplicate the factory installation with the front trunk opening. |
JOEPROPER |
Apr 25 2020, 06:30 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I forgot to mention that I needed to change the angle of the supply nipple on the tank. The supply nipple is rotated almost parallel to the tank but about 5 degrees from parallel One advantage or two is that it is easier to remove tank and reinstall. The tank can be drained by undoing the strait reducer and you can attach the supply hose to the tank before you put it in and then attach to the reducer. This part is very helpful. I had to do the same when i installed my fuel pump too. |
bdstone914 |
Apr 25 2020, 08:18 AM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@rstover
Did you upgrade to stainless steel lines in the tunnel? When they changed to the front mounted pump they changed to a tougher polymide line. The lines were pressurized with the front mounted pump unlike the early lines with a rear pump carried no positive pressure. |
rstover |
Apr 25 2020, 10:47 AM
@rstover Did you upgrade to stainless steel lines in the tunnel? When they changed to the front mounted pump they changed to a tougher polymide line. The lines were pressurized with the front mounted pump unlike the early lines with a rear pump carried no positive pressure. Yes I had already changed to the stainless steel line. That is a very important safety point when switching the pump to the front. I probably should have mentioned that. Thanks for pointing that out. |
rstover |
Apr 25 2020, 11:24 AM
This picture might be helpful. Maybe I should have mentioned that I used fender washers on the inside to mount bracket.
Lo-Fi Version | Time is now: 28th May 2024 - 03:14 PM |
