Push Rod Choice for 2.0/4 |
Charles Freeborn |
Apr 25 2020, 04:43 PM
Member Group: Members Posts: 249 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Need a new set - 1 bent.
Recs? Moderatly built 2.0. Running Scat dual springs, webcam 86b. Thx. |
yeahmag |
Apr 29 2020, 11:58 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I run chromoly push rods.
http://www.europeanmotorworks.com/vw/type-...s-pushrods.html Why did the current one bend? |
Charles Freeborn |
Apr 30 2020, 12:13 AM
I run chromoly push rods. http://www.europeanmotorworks.com/vw/type-...s-pushrods.html Why did the current one bend? That’s my plan. Ordered a fresh set. I actually got lucky. I had a couple of broken valve springs, then missed a shift and over revved. I’m lucky I don’t didn’t lunch the whole engine. |
stownsen914 |
May 2 2020, 06:33 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
You probably thought of this already, but if a piston contacted a valve, you might want to replace rods bearings to be safe.
Charles Freeborn |
May 3 2020, 06:43 PM
You probably thought of this already, but if a piston contacted a valve, you might want to replace rods bearings to be safe. Good advice, but fortunately not the case. Pulled all pistons, cyls to inspect and re-ring. Heads all the way apart, 5 angle grind - all straight and fine. Not really sure exactly why the p rod bent, but there was no other damage. Mysteries abound.. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:17 PM |
