Another No Start, Thought I solved it.. NOPE did it again. |
Olympic 914 |
Sep 4 2020, 12:00 PM
Group: Members Posts: 1,672 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
The trans bolt stud area should be shiny clean and the nut tight, the solenoid grounds through the bracket. Mark, thanks for sticking with me on this. I am going to take the multimeter and do some resistance tests from the ford relay bracket to trunk ground and between a couple other points before I take anything apart. Would like to be able to pinpoint a fault rather than just hoping I fixed it. Don't understand why it would be a HOT start issue. If you have a bad ground it would be bad regardless of the temp, right? |
Lo-Fi Version | Time is now: 29th May 2024 - 01:16 AM |
