How to replace fan belt...HELP!, How do you get the belt on? |
Ampex351 |
May 9 2020, 10:27 AM
Member Group: Members Posts: 104 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest |
I've had this little car a week now and it's killing me because the first day I drove it home the fan belt came off. I coud hear it thrashing around in there but I have no clue as to what is the proper method of getting at it to replace it. Any info to refer to? Do any of you know how to get the belt on? I'd love to go driving!!!
Thanks, Roger |
simonjb |
May 9 2020, 10:46 AM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
I just did this yesterday.
First you need to loosen the top adjustment bolt on the alternator and that will allow you to pivot the alternator up and towards the fan. I also had to get under the car and loosen the bottom pivot bolt as it was so tight that I could not pivot the alternator. PIA as I had to remove some of the heating connections. Once I loosened the bottom pivot I pushed the alternator up and towards the fan and then tightened the bottom pivot bolt to hold it there while I put the belt on. There are two entry point holes/covers in the top side sheet metal that let you get to the top bolt. Key to fan belt I found is place belt around fan and then start it on the alternator. Then using a size 22 wrench I turned the alternator pulley as I pushed against the belt and it road up and on to the pulley. Then I slightly loosened the bottom pivot bolt and went top side again. I used a long screw driver to push down on the alternator to get the proper belt tension and at the same time I tightened the top adjustment bolt. Finally I went below and tightened the pivot bolt slightly - but not too much so that next time it should just pivot after I loosen the top adjustment bolt. |
GregAmy |
May 9 2020, 10:47 AM
Advanced Member Group: Members Posts: 2,309 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
First result from a search: http://www.914world.com/bbs2/index.php?showtopic=38596 |
Ampex351 |
May 9 2020, 11:03 AM
I just did this yesterday. First you need to loosen the top adjustment bolt on the alternator and that will allow you to pivot the alternator up and towards the fan. I also had to get under the car and loosen the bottom pivot bolt as it was so tight that I could not pivot the alternator. PIA as I had to remove some of the heating connections. Once I loosened the bottom pivot I pushed the alternator up and towards the fan and then tightened the bottom pivot bolt to hold it there while I put the belt on. There are two entry point holes/covers in the top side sheet metal that let you get to the top bolt. Key to fan belt I found is place belt around fan and then start it on the alternator. Then using a size 22 wrench I turned the alternator pulley as I pushed against the belt and it road up and on to the pulley. Then I slightly loosened the bottom pivot bolt and went top side again. I used a long screw driver to push down on the alternator to get the proper belt tension and at the same time I tightened the top adjustment bolt. Finally I went below and tightened the pivot bolt slightly - but not too much so that next time it should just pivot after I loosen the top adjustment bolt. |
Ampex351 |
May 9 2020, 11:05 AM
I've had this little car a week now and it's killing me because the first day I drove it home the fan belt came off. I coud hear it thrashing around in there but I have no clue as to what is the proper method of getting at it to replace it. Any info to refer to? Do any of you know how to get the belt on? I'd love to go driving!!! Thanks, Roger Do I jack up the car from under the engine or the side? I have an opportunity to take it in to a shop with a lift next week and have a mechanic look at it. He's never done it before but said he would figure it out. Just wish it was do-able in my own garage. Roger |
Bleyseng |
May 9 2020, 11:37 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Yes, just jack it up on the drivers side and use a jack stand !! Safety first. Its easy to then get under to loosen the nut on the bottom of the alt. You need a allen head or hex to loosen the top bolt after removing the access little plastic covers if they are even there. (order some from 914Rubber). The belt needs to be able to flex up and down about a 1" of slack. Too loose and it will come off. Check the condition of the belt too and make sure its the right size. (Same as a VW bus 72-79)
Ampex351 |
May 9 2020, 11:56 AM
Yes, just jack it up on the drivers side and use a jack stand !! Safety first. Its easy to then get under to loosen the nut on the bottom of the alt. You need a allen head or hex to loosen the top bolt after removing the access little plastic covers if they are even there. (order some from 914Rubber). The belt needs to be able to flex up and down about a 1" of slack. Too loose and it will come off. Check the condition of the belt too and make sure its the right size. (Same as a VW bus 72-79) Do I access those little covers from underneath? |
simonjb |
May 9 2020, 12:43 PM
Yes, just jack it up on the drivers side and use a jack stand !! Safety first. Its easy to then get under to loosen the nut on the bottom of the alt. You need a allen head or hex to loosen the top bolt after removing the access little plastic covers if they are even there. (order some from 914Rubber). The belt needs to be able to flex up and down about a 1" of slack. Too loose and it will come off. Check the condition of the belt too and make sure its the right size. (Same as a VW bus 72-79) Do I access those little covers from underneath? No - they are on top - black plastic oblong |
Ampex351 |
May 9 2020, 02:00 PM
Yes, just jack it up on the drivers side and use a jack stand !! Safety first. Its easy to then get under to loosen the nut on the bottom of the alt. You need a allen head or hex to loosen the top bolt after removing the access little plastic covers if they are even there. (order some from 914Rubber). The belt needs to be able to flex up and down about a 1" of slack. Too loose and it will come off. Check the condition of the belt too and make sure its the right size. (Same as a VW bus 72-79) Do I access those little covers from underneath? No - they are on top - black plastic oblong Thanks everyone, I appreciate the insight. |
Lo-Fi Version | Time is now: 28th May 2024 - 08:15 AM |
