72' Tailshifter Tranny Bummer, Stuck in reverse |
Flat VW |
Jul 8 2005, 08:32 AM
Illegal Soapbox Derby Racecar Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 |
Hello to all,
Well my daily driver is down, stuck in reverse. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) My garage, after a consult with a more knowing outfit, says the tranny is junk. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Please note, my garage says it is not the linkage that is jammed, but that it is jammed within the transaxle itself..... Comments, Questions, Suggestions? Thanks in advance, John (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
ClayPerrine |
Jul 8 2005, 08:35 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Put the car on a lift.
Remove the shift linkage. Unhook the tranny mounts and drop the rear of the tranny downward, with the tranny case sitting on a pole jack. Remove the tail housing. Pull the gearstack and inspect. Take lots of pictures. Post pictures here so we can help. |
rhodyguy |
Jul 8 2005, 09:19 AM
before you go ANY futher. drain the gear lube and remove the the small access plate on the bottom of the rear of the trans. there is a triple rolled pin that connects a selector to a shaft. when the pin goes completely away you can't change gears. have a catch pan ready as some lube will come out. if it's the pin order 2 (one for a spare) and a new gasket.
k |
Flat VW |
Jul 8 2005, 08:02 PM
From your computer to God's ear. John |
jr91472 |
Jul 8 2005, 08:08 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
listen to Clay....
From the perspective of paying someone to do it for you, it is junk. But you can do this yourself......take it apart and take pictures. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
ClayPerrine |
Jul 8 2005, 08:10 PM
Actually check the pin in the tailshifter linkage. It's been a long time since i dealt with a tailshifter and I forgot that. If the pin is ok, pull the stuff like I suggested in the other post.
We can walk you through the fixes. All you need is a digital camera and some faith in your fellow club members. |
Flat VW |
Jul 8 2005, 08:14 PM
Thanks, Clay, Jr, others, I have to work thruout the weekend and also need the car towed back here but I am up to give it a go, perhaps next week. THX, John |
Trevorg7 |
Jul 8 2005, 08:42 PM
Senior Member Group: Members Posts: 1,242 Joined: 7-December 04 From: Highland Village, TX Member No.: 3,241 Region Association: Southwest Region |
I'd have to agree with rhodyguy. I have a '72 and when downshiftig from 5th to 4th at freeway speed I lost every gear. Turned out to be the roll pin. The DPO had put in a threaded bolt that sheered. I was able to get a new roll pin from HPH and installed through the rear access plate, with a new gasket, in about an hour.
Hope this helps. Good luck. Trevor |
rhodyguy |
Jul 8 2005, 08:55 PM
i can't stress getting the triple rolled pin enough. the single or double rolled won't do the job for long. note the orientation of the selector. don't ask (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) . i was glad i ordered 2. you will prob need a small punch to get the remains of the pin out.
k |
Flat VW |
Jul 8 2005, 08:59 PM
Yes, Rhodyguy, I will check it out, as soon as I am done stareing at Lyressa!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Well, next week actually, Thanks again, John |
9144guy |
Jul 8 2005, 09:00 PM
Member Group: Members Posts: 253 Joined: 26-February 05 From: tulsa,ok Member No.: 3,672 |
just had a 915 tranny that did the same thing, it would stick in 2 gears at the same time. took fork plate off twice and un-jamed it ,then pulled trans..(its a 78 911) ..and found the detents were not installed properly a while back and finaly showed throgh
Lo-Fi Version | Time is now: 17th May 2024 - 09:00 PM |
