914-6 Conversion Shift Linkage Question, (Firewall Back) |
RichPugh |
May 10 2020, 04:29 PM
Member Group: Members Posts: 124 Joined: 28-October 14 From: Baltimore, MD Member No.: 18,068 Region Association: MidAtlantic Region |
So... the engine is in (I’m using the NaroEscape -6 front mount) and, seeming because of the mount, it sits lower than stock. The Patrick Motorsport -6 shift linkage rod I intended on using, wont work. It interferes with the engine case and doesn’t seem to have a workaround. If the engine were 1/4” - 1/2” higher at the firewall, it looks like it would slip in, but alas, the engine is not going anywhere, lol.
I’m tempted to just bend the PMS bar end upward (maybe a couple inches from where it goes from the narrow shank to the bar rod) to give it the clearance but that would change the angle it goes into the rear bushing and connects to the shift lever... so I figured I’d ask if anyone else had an issue with the bar hitting the engine case and any options I might have. I’m OK with modding the old -4 rod too. Might be worth a shot but figured I’d ask here first. The other threads I found look like the stock rod modded is the move. Thanks Rich |
mb911 |
Sep 21 2020, 07:35 AM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I would highly recommend it .. I personally have now gone to suggestions of using either the Rich Johnson mount or the maddog OEM style to eliminate this issue. The heater valves are also an issue that has to be worked around with the Naro mount.
RichPugh |
Sep 21 2020, 08:13 AM
I would highly recommend it .. I personally have now gone to suggestions of using either the Rich Johnson mount or the maddog OEM style to eliminate this issue. The heater valves are also an issue that has to be worked around with the Naro mount. Yea... I havent even gotten round to the heat valves (IMG:style_emoticons/default/rolleyes.gif) I'm just hoping I get SOME heat to defrost the windshield. Just worked out some fresh air blower motor gremlins yesterday so fingers crossed, LOL. Yea I agree... I'd say if Naro made the bottom of their mount plates like 3/4" taller so it lifted the engine up 3/4" but still lined up the same on the firewall ridges, it would be much better. The engine tins would seal correctly, the shift rod clearance wouldnt be an issue, and the only other issues would be with the line to the rear brake valve and whatever I'm not seeing yet with the heater valves. I dont see the benefit of it sitting as low as it does now. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:06 AM |
