914-6 Conversion Shift Linkage Question, (Firewall Back) |
RichPugh |
May 10 2020, 04:29 PM
Member Group: Members Posts: 124 Joined: 28-October 14 From: Baltimore, MD Member No.: 18,068 Region Association: MidAtlantic Region |
So... the engine is in (I’m using the NaroEscape -6 front mount) and, seeming because of the mount, it sits lower than stock. The Patrick Motorsport -6 shift linkage rod I intended on using, wont work. It interferes with the engine case and doesn’t seem to have a workaround. If the engine were 1/4” - 1/2” higher at the firewall, it looks like it would slip in, but alas, the engine is not going anywhere, lol.
I’m tempted to just bend the PMS bar end upward (maybe a couple inches from where it goes from the narrow shank to the bar rod) to give it the clearance but that would change the angle it goes into the rear bushing and connects to the shift lever... so I figured I’d ask if anyone else had an issue with the bar hitting the engine case and any options I might have. I’m OK with modding the old -4 rod too. Might be worth a shot but figured I’d ask here first. The other threads I found look like the stock rod modded is the move. Thanks Rich |
nditiz1 |
Sep 24 2020, 06:18 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
@richpugh I have a modified shift shaft that Ben did for my build. It has a slight bend and will be used with the oem style mount. You are more than welcome to try it out since I'm not close to that part in my build. Just let me know, I'm probably about a 30 - 40min drive for you.
RichPugh |
Sep 24 2020, 08:43 PM
@richpugh I have a modified shift shaft that Ben did for my build. It has a slight bend and will be used with the oem style mount. You are more than welcome to try it out since I'm not close to that part in my build. Just let me know, I'm probably about a 30 - 40min drive for you. Thanks! Will totally try it out! I'll be there in 45 minutes! LOL. You avail this weekend? |
Lo-Fi Version | Time is now: 18th May 2024 - 12:44 PM |
