914-6 Conversion Shift Linkage Question, (Firewall Back) |
RichPugh |
May 10 2020, 04:29 PM
Member Group: Members Posts: 129 Joined: 28-October 14 From: Baltimore, MD Member No.: 18,068 Region Association: MidAtlantic Region |
So... the engine is in (I’m using the NaroEscape -6 front mount) and, seeming because of the mount, it sits lower than stock. The Patrick Motorsport -6 shift linkage rod I intended on using, wont work. It interferes with the engine case and doesn’t seem to have a workaround. If the engine were 1/4” - 1/2” higher at the firewall, it looks like it would slip in, but alas, the engine is not going anywhere, lol.
I’m tempted to just bend the PMS bar end upward (maybe a couple inches from where it goes from the narrow shank to the bar rod) to give it the clearance but that would change the angle it goes into the rear bushing and connects to the shift lever... so I figured I’d ask if anyone else had an issue with the bar hitting the engine case and any options I might have. I’m OK with modding the old -4 rod too. Might be worth a shot but figured I’d ask here first. The other threads I found look like the stock rod modded is the move. Thanks Rich |
nditiz1 |
Sep 25 2020, 12:16 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
@tdskip try to return the naroscape if you can and go with the mad dog oem. Its a little more, think I padis ~400 for the mount and bushing, but it will be worth it having everything sit where it is supposed to.
JOEPROPER |
Sep 25 2020, 01:01 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
@tdskip try to return the naroscape if you can and go with the mad dog oem. Its a little more, think I padis ~400 for the mount and bushing, but it will be worth it having everything sit where it is supposed to. Sounds like there are going to be mods either way. I'm going to mount my Naro Escape mount 3/4" higher with engine and trans installed to make sure installed height and angles are correct. This will be my first conversion on a 914 and like everyone else, will deal with whatever modifications need to be made. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 11:55 PM |
