914-6 Conversion Shift Linkage Question, (Firewall Back) |
RichPugh |
May 10 2020, 04:29 PM
Member Group: Members Posts: 129 Joined: 28-October 14 From: Baltimore, MD Member No.: 18,068 Region Association: MidAtlantic Region |
So... the engine is in (I’m using the NaroEscape -6 front mount) and, seeming because of the mount, it sits lower than stock. The Patrick Motorsport -6 shift linkage rod I intended on using, wont work. It interferes with the engine case and doesn’t seem to have a workaround. If the engine were 1/4” - 1/2” higher at the firewall, it looks like it would slip in, but alas, the engine is not going anywhere, lol.
I’m tempted to just bend the PMS bar end upward (maybe a couple inches from where it goes from the narrow shank to the bar rod) to give it the clearance but that would change the angle it goes into the rear bushing and connects to the shift lever... so I figured I’d ask if anyone else had an issue with the bar hitting the engine case and any options I might have. I’m OK with modding the old -4 rod too. Might be worth a shot but figured I’d ask here first. The other threads I found look like the stock rod modded is the move. Thanks Rich |
RichPugh |
Sep 28 2020, 03:45 PM
Rich and Nick the only issue with using that linkage I moded is it was not modded for a naro mount Hey Ben, think you could make another bar like the one you made that I borrowed from Nick, but put a nice big notch in it to easily clear my -6 case? Pic posted above is the general parameters that would work. |
Lo-Fi Version | Time is now: 20th May 2024 - 12:18 AM |
