914-6 Conversion Shift Linkage Question, (Firewall Back) |
RichPugh |
May 10 2020, 04:29 PM
Member Group: Members Posts: 124 Joined: 28-October 14 From: Baltimore, MD Member No.: 18,068 Region Association: MidAtlantic Region |
So... the engine is in (I’m using the NaroEscape -6 front mount) and, seeming because of the mount, it sits lower than stock. The Patrick Motorsport -6 shift linkage rod I intended on using, wont work. It interferes with the engine case and doesn’t seem to have a workaround. If the engine were 1/4” - 1/2” higher at the firewall, it looks like it would slip in, but alas, the engine is not going anywhere, lol.
I’m tempted to just bend the PMS bar end upward (maybe a couple inches from where it goes from the narrow shank to the bar rod) to give it the clearance but that would change the angle it goes into the rear bushing and connects to the shift lever... so I figured I’d ask if anyone else had an issue with the bar hitting the engine case and any options I might have. I’m OK with modding the old -4 rod too. Might be worth a shot but figured I’d ask here first. The other threads I found look like the stock rod modded is the move. Thanks Rich |
JOEPROPER |
Nov 6 2020, 10:55 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
@RichPugh How did you make out with that engine mount?
RichPugh |
Nov 11 2020, 10:58 AM
I was able to ignore it while procrastinating and doing nothing. Well, doing other stuff, completely unrelated to the 914, as per the 914 project handbook, "Step 4: Stop working on 914 and do other stuff". LOL I'm planning to finish the stuff in the front this week or next... I.e., putting the fresh air blower box and fan back in, wiring and plumbing the fuel pump, dropping the tank back in... THEN I can roll it off the lift, spin the lift around, put it BACK up in the air with the lift positioned where I can remove the engine... and THEN I'll stare at the mount until I repeat step 4 again. The goal is to weld a new plate to the face of the engine side of the mount with the holes positioned up 3/4"-1" upwards... that should do it. -Rich |
Lo-Fi Version | Time is now: 17th May 2024 - 02:50 AM |
