| brcacti |
May 11 2020, 04:01 PM
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
So no one had this in stock, many could not even order it. Napa said they just ordered it for me, gasket for strainer and crush washer. I believe I have the only porsche 914 in this town/city of Casa Grande, AZ.
| iankarr |
May 11 2020, 04:07 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,609 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Assume you're talking about the strainer kit, right? Did you try 914rubber? I have an extra kit if you need it.
| 914e |
May 11 2020, 05:05 PM
Member ![]() ![]() Group: Members Posts: 497 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region
Auto Haus has it up in Phoenix. They are only open 8-4 weekdays
| Mark Henry |
May 11 2020, 05:33 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Any air cooled VW shop will have them, many places have packs of 10.
FLAPS having it isn't likely as it's too old. |
| brcacti |
May 12 2020, 05:42 PM
Thanks guy, this is my off season for driving it so anytime this week on order will do fine. Napa ordered it for me, will be in this week. One place I called said "a Porsche part?" "no one around here can afford a Porsche, hehe. ONE MORE QUESTION (IMG:style_emoticons/default/smile.gif), I have the rear up on 8-9 inch ramps, is there a jack point up front anywhere I can jack up the car to but 2x6
wood under the front tires to partly level it off to get more oil out and have more room to work? |
| iankarr |
May 12 2020, 09:40 PM
After a while you get a sense of when to call this a porsche and when to call it a VW (IMG:style_emoticons/default/wink.gif). Your engine is a VW type 4...so anyplace that sells bug parts should be good.
As for leveling the car, you're probably best off getting 4 jack stands. Ramps are kind of a pain, unless you have a way to keep them from sliding. If already up, you can use 2 stands in the front to level. Please buy the dual locking or pin type...not the single ratcheting, which are far more prone to accidents. Like this... https://www.amazon.com/Pro-LifT-T-6902D-Dou...tive&sr=1-2 |
Lo-Fi Version | Time is now: 1st November 2026 - 06:08 PM |
