engine oil Galley plugs, How many Engine oil galley plugs are there ?? |
02loftsmoor |
May 11 2020, 08:56 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
need some help ,
how many oil galley plugs are there? two on the front and two at the rear of the engine?? thanks in advance Wes (IMG:style_emoticons/default/idea.gif) |
Tbrown4x4 |
May 12 2020, 03:06 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
More like 7 or 8. I'll have to look at my case, but there are 2 or 3 on the flywheel end, 1 on the passenger side, 2 on the front, and 2 to the oil cooler. I'm not sure if people replace all of them with threaded plugs or not, but mine are.
BeatNavy |
May 12 2020, 05:19 AM
You can do all of them, but I think most people do the 5 larger ones -- the ones that are most susceptible to blowing (the smaller ones apparently not).
Here's a good reference which ones: http://www.914world.com/bbs2/index.php?s=&...t&p=1275897 |
Superhawk996 |
May 12 2020, 06:48 AM
914 Guru Group: Members Posts: 5,816 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
You can do all of them, but I think most people do the 5 larger ones -- the ones that are most susceptible to blowing (the smaller ones apparently not). Here's a good reference which ones: http://www.914world.com/bbs2/index.php?s=&...t&p=1275897 There are 11 in total. I know in my situation, out of the two cases I have, at least one of the small plugs was loose and showed evidence of weeping. It took very little force to pull that one out vs. the majority of the others. Photos of many of them are at this thread pages 3 & 4: http://www.914world.com/bbs2/index.php?sho...38513&st=60 |
Tbrown4x4 |
May 12 2020, 06:59 AM
Thanks for posting that. Now I can just go home and go to bed! I forgot about a few of those. It's been a while. haha
02loftsmoor |
May 12 2020, 08:09 AM
So from what I'm looking at , just replace the bigger plugs,,
Mark Henry |
May 12 2020, 09:04 AM
So from what I'm looking at , just replace the bigger plugs,, Yes, only the big 5, I've never seen any of the small plugs leak, just the big ones. I had a customer who tried to do the others, he drilled into the totally wrong area of the relief and ruined a good 2.0 case. |
02loftsmoor |
May 12 2020, 02:29 PM
Thank you every one.
now isn't there an updated oil pressure release valve? |
BeatNavy |
May 12 2020, 02:56 PM
Chris Foley at Tangerine Racing sells one. On this page: http://www.tangerineracing.com/engine.htm
02loftsmoor |
May 23 2020, 10:14 AM
Mark Henry |
May 23 2020, 10:51 AM
Good job (IMG:style_emoticons/default/thumb3d.gif)
The hole on the left first pic you have to make sure the plug sits close to flush or it will hit the flywheel, At the same time you need to take care not drill in too far, but it's OK if the threads (not the plug!) reach the first small galley. The plug can only sit about an 1/8" proud. |
Superhawk996 |
May 23 2020, 10:53 AM
(IMG:style_emoticons/default/yikes.gif) Didn't realize you were drilling and tapping on an assembled engine.
Please clean those galleys out very carfully to ensure no swarf has entered the galley. Maybe with a long car detailing Q-tips with oil on the cotton end to help "grab" any debris? |
Mark Henry |
May 23 2020, 11:03 AM
BTW the 2nd pic the right (top) hole is where you would install a 90 degree street elbow if doing a full flow system.
For race or upper tier performance cars usually for running a front cooler. You would plug the pump and use a T1 full flow cover, remote filter, etc. |
Mark Henry |
May 23 2020, 11:11 AM
(IMG:style_emoticons/default/yikes.gif) Didn't realize you were drilling and tapping on an assembled engine. Please clean those galleys out very carfully to ensure no swarf has entered the galley. Maybe with a long car detailing Q-tips with oil on the cotton end to help "grab" any debris? I've done this many times, grease the tap and clean it often. I always warn that it could go bad, but I've never lost an engine. Besides the repair is often for a plug leak or blow out, so either way the engine is fuched. Cleaning the tap is key, never counted but I likely clean and re-grease 10 times per hole. |
02loftsmoor |
May 23 2020, 01:13 PM
(IMG:style_emoticons/default/yikes.gif) Didn't realize you were drilling and tapping on an assembled engine. Please clean those galleys out very carfully to ensure no swarf has entered the galley. Maybe with a long car detailing Q-tips with oil on the cotton end to help "grab" any debris? I've done this many times, grease the tap and clean it often. I always warn that it could go bad, but I've never lost an engine. Besides the repair is often for a plug leak or blow out, so either way the engine is fuched. Cleaning the tap is key, never counted but I likely clean and re-grease 10 times per hole. I'm using compressed. get those little barnacles out there |
02loftsmoor |
May 23 2020, 03:53 PM
Good job (IMG:style_emoticons/default/thumb3d.gif) The hole on the left first pic you have to make sure the plug sits close to flush or it will hit the flywheel, At the same time you need to take care not drill in too far, but it's OK if the threads (not the plug!) reach the first small galley. The plug can only sit about an 1/8" proud. i was wondering about that, i will watch out |
02loftsmoor |
May 23 2020, 09:25 PM
Mark Henry |
May 24 2020, 09:18 AM
Flywheel 1/2 side plug still looks too proud and may touch the flywheel.
02loftsmoor |
May 24 2020, 09:24 AM
Mark Henry |
May 24 2020, 11:40 AM
Flywheel 1/2 side plug still looks too proud and may touch the flywheel. I will me watching for that on assembly, thank you for the tip!!!! Time to fix this is now. (IMG:style_emoticons/default/smile.gif) Stick the flywheel on now, don't worry about a seal yet, check the plug and it will be hitting You can grind a bit off the two ends of the plug, but only so much on the hex drive end. The NPT thread is a taper thread so you will have to drill and tap the hole deeper, so the plug will sit in deeper. This is the hole that makes me prefer steel plugs, because steel has the strongest hex drive. I don't like Teflon sealant (on plugs) as you could over torque and crack the bung, never seen this with the T4 but I've seen this with T1 cases. I use green locktite. |
Lo-Fi Version | Time is now: 14th May 2024 - 11:34 PM |
